Hey guys, my turbo oil feed line started leaking and needs to be replaced. Not quite spraying but it lost about 1/2 a quart in 70 miles home on road trip. I was looking online for a braided SS replacement and found one on darkside dev. My problem is I noticed stock hardline has one banjo fitting whereas the darkside one has two. Will this part still work, and if it is the wrong part where can I find the right one? This is the one I found on darkside. Its a 98 w/ AHU. Feed line runs from top of oil filter housing to turbo.
Car is my DD and I know its probably a mistake but I will continue driving it to work, as I have no other mode of transportation. Hopefully the line holds together enough until I can get a replacement. So any immediate help would be greatly appreciated so that I can get the ball rolling on ordering a part. Thanks in advance.
