Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Mid-west USA
Mid-west USA Local discussions for those on the Mid-West US. ( Minnesota, Iowa, Wisconsin, Michigan, Illinois, Indiana, Ohio, Nebraska, North Dakota, South Dakota, Kansas, Missouri)
Old August 18th, 2016, 10:49   #7561
DI fan
Fuel Economy: 42 city(wife) 44 city(me) 48 highway. Best 52
Originally Posted by Curious Chris View Post
Weird noises on my 2002: sometimes not all the times when I am coming to a stop when i hit the brakes I here a cluink, and if I pump the brakes I here the clunk over and over again. Then today no sound. What the f**k?
If it's anything like the noise I have it may be upper strut bearings. My noise it more of tick though. I happens when I hit the brakes, when I engage/disengage the clutch and when I get on and off the the accelerator.
DI fan is offline   Reply With Quote
Old August 18th, 2016, 19:33   #7562
Curious Chris
Fuel Economy: 47/42/38
Originally Posted by [486] View Post
Got a compact spare from a PT cruiser that fits mine, iirc the center hole's real big so it's lug centric though.
Ooh VW's are hub centric and the lug bolts just hold it in place and the hub supports all the weight.
Curious Chris is offline   Reply With Quote
Old August 18th, 2016, 20:41   #7563
[486]
TDI(s): 02 golf ALH
If you don't tell the studs I won't either, it can be our little secret
Which is to say that if the hub pilot were carrying the load, it would be moving by the amount of clearance between the wheel bore and the hub pilot every time the wheel rotated. Obviously that's not the case with how solidly aluminum wheels sieze onto the hub. All the weight is carried by the wheel being clamped to the hub by (5) 14mm bolts torqued to whatever ft/lb (mine are zapped on with a 100ft/lb torque stick, so about 110 ft/lb) making some absurd amount of clamp load (around 15k lbs times five lugs)
[486] is offline   Reply With Quote
Old August 20th, 2016, 16:25   #7564
Curious Chris
I just replaced the passenger side upper strut bear and it does seem quieter. Maybe onto the driver's side.
Old August 31st, 2016, 13:34   #7565
JFettig
JFettig's Avatar
Who all is going to TDI Fest this weekend? I only see a few of you guys on this list: http://forums.tdiclub.com/showthread.php?t=462449
Minnesota Malone Tuning dealer
1998 B5 Passat TDI Compound Turbos
2009 JSW Stage 3 196whp so far
DIY injector calibration http://forums.tdiclub.com/showthread.php?t=383324
JFettig is offline   Reply With Quote
Old September 1st, 2016, 08:20   #7566
Curious Chris
My wife's Birthday is Monday so not me. And if it was my birthday Monday we would be there!
Old September 5th, 2016, 20:18   #7567
JasonCzerak
TDI(s): 2001 Golf
Been a while since i posted around here! Sold my 01 Golf TDI a month or so ago, replaced it with a 2012 Wagon TDI w/dsg.
My only compliant is the sound system quality sucks.
Jon will be putting tunes in it shortly after VW gets their act together
2012 Jetta SportWagon TDI - Stock
2006 Golf TDI - Malone Stage 1.5
2006 Corvette - 805whp - KL Tunes
JasonCzerak is offline   Reply With Quote
Old September 6th, 2016, 19:12   #7568
[486]
TDI(s): 02 golf ALH
Did that blue A4 wagon ever get found?
Saw one that real bright blue, lowered, aftermarket wheels, debadged and LED plate lights in st. anthony an hour ago.
Old September 7th, 2016, 03:16   #7569
JFettig
JFettig's Avatar
Yes it was found.
Old September 7th, 2016, 12:49   #7570
[486]
TDI(s): 02 golf ALH
Cool, then I don't gotta wonder if I should have chased after the guy to see if it was a diesel.
Old September 16th, 2016, 07:05   #7571
Curious Chris
Well my engine vibration issue is resolved: threw a rod this morning. Looking at long blocks..........
Old September 16th, 2016, 11:40   #7572
DWNUNDR
TDI(s): 03 Golf TDi
Fuel Economy: 43.41, 44.99, 48.64
I have some rims off of a ford.. 5x112 I believe so they should fit some later VW's.. they have snow tires on them with at least 80% life left..
won them on an auction took a chance they would fit as there was no description for what they came off of... 16inch rims fyi
looking to get $400 obo
http://minneapolis.craigslist.org/da...745849032.html
I am actually after bigger rims for my 03 Golf TDi or even a spare set of stockers for winter setup 5x110
DWNUNDR is offline   Reply With Quote
Old September 16th, 2016, 23:21   #7573
TornadoRed
TornadoRed's Avatar
5x100 for Mk4 Golfs, Jettas, and New Beetles.
Also, CL respondents will offer you $100 or $150 for 4 used tires and steel rims. You should hold out for at least $200-250, or a little more after the first significant snowfall.
Your ad should have Firestone Winterforce in bold, or at least a little more prominent. Maybe something about how well rated they are - are they?
'03 Golf with 721k miles: Bosio DLC 764, GT1749VB, PP 2.5" downpipe, Malone tuning, VR6/G60 clutch/flywheel, Bilstein HDs, Recaros, Akebono pads/Brembo rotors, Cat filter with Nicktane head, DG Panzer w/FMJ, Pirelli Cinturato P7 AS+, TDT/Delvac1
Like TDI Club? Got PayPal? Got $1 or $5 or $10? Contribution link on the main page.
TornadoRed is online now   Reply With Quote
Old September 18th, 2016, 08:35   #7574
JasonCzerak
TDI(s): 2001 Golf
By chance anyone of a handful of the pins laying around? This is for my 2012 wagon. specifically the asv plug
Old September 18th, 2016, 08:36   #7575
JFettig
JFettig's Avatar
You can get a repair wire from the dealer.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Page generated in 0.25654 seconds with 10 queries
[Output: 128.13 Kb. compressed to 107.10 Kb. by saving 21.03 Kb. (16.41%)]
