Quirky 6M
bruce846
North Central Pangaea
No TDI's
Anyone with a 6M noticed if you inadvertently push dow on the shift lever when making the 1st/2nd shift you will catch a little reverse on the way... or am I a clutz?
40X40
Experienced
Kansas City area, MO
2013 Passat SEL Premium
Don't rest the weight of your hand on the gearshift.....
Bill
jnecr
Raleigh, NC
2014 BMW 328d
You're a klutz... I'm guessing this is your first VW? You'll get used to it. :)
flylow2
Hillsborough, NJ
2010 White Gold JSW TDI 6M (build date 23Feb10)
how do you catch reverse on the 1st to 2nd shift? Reverse is to the left of first. You have to go down, over, then up to catch reverse. I also find I push down a bit when shifting ocassionally but it does not cause any problems.
PlaneJob
Wylie, TX
2010 JSW TDI
Fly low, I think he's catching, what might be described as, the 'edge of the gate' for the initial movement to the left when selecting reverse. (I just went out and tried this on my car to see).
OP, use the armrest to hold your arm and hand up! When you put weight on the shifter you can cause abnormal wear, when in gear or out of gear. Shift with your fingers. Avoid the baseball inspired death grip and hold it lightly, like you would hold a toothbrush...
ToeBall
Houston, TX
2010 VW Jetta Wagon TDI
I don't snag the gate, but I would almost kill for stiffer centering springs for the shifter.
bruce846
No TDI's
PlaneJob got it right.
