I believe my timing belt jumped. I think this cause I was driving down the road and it just died! It would not restart but turnes over still. The belt is not broken. I looked in the engine compartment and found the timing belt cover broke in a few places and a small 12mm nut (flanged) laying there. I think maybe someone lost a nut or something cause so far I have found no loose ones(besides myself).My engine still turns over by hand so I think maybe I am lucky and didn't hurt nuttin? I found tdc on the flywheel and looked like everything was 180 degrees and then some off. After thinking on it, maybe I was not at TDC on #1 cylinder but TDC on #3 cylinder? Also is there a way to set the injector pump up with out a computer? I am going to go get a allen socket from a buddy so I will check back. Thanks for your Help
