G60ING
- Joined
- Aug 5, 2001
- Location
- MD
- TDI
- No TDIs Currently, I have an R36 Corrado. I've had an ALH Corrado swap, AHU Corrado swap and 2003 TDI Jetta
Measuring Cylinder Bore & Piston Protrusion Measuring Questions
Ok I'm not sure of the best location for this thread but I know most of you hardcore modded TDIs have had to cover this at some point.
What tools are you using to measure the cylinder bore diameter? I just tried the cheap telescoping gauge set (also called snap gauges) from Harbor freight.
I plan on getting a little more precise tool from summit racing since the harbor freight tool was a pita to use:
For the Piston Protrusion I figured out how to get a measurement but it took more time then I thought. Using a magnetic base I was thinking I could sweep the dial indicator out and get a measurement but because of all the angles I figured that it was accurate that way. I ended up getting my measurement in one spot and then released the magnet and repositioned the dial and stand without moving any of the joints. This worked well. I also learned that the point directly above the wrist pin was the best spot for the peak measurement. Is this similar to others' experiences? Any tips?
This is the first time I've had to do this and I'd like to do it right. I'm open to any tips or suggestions on tools and technique. Thanks
