sdeck
- Joined
- Aug 25, 2006
- Location
- Northern Colorado Front Range
- TDI
- 2003 Jetta, 253K, 01M, DLC520s, VNT-17(sold); 2014 Passat SE 6M, 61,000 miles (Feb 16 buyback date)
My 03 Jetta (120K) has been burning (NOT leaking) oil at a rate of about 1 quart every 2000 miles for at least 30K. This car has been running WVO for 40K, diesel only for last 1000-1500. After scraping the serious carbon build up off the intake valves and ports, the power is way up, smoke is way down, and oil consumption has about doubled. My compression has always been good (~480 x 4), turbo does not seems to be overly loose (tiny bit of side-to-side play, zero in-out) but I don't know what the tolerances are.
There has always been liquid oil in the CCV/air intake tube. The intercooler never drips when I pop the hose, though there is always a 1/8" to 3/16" film on the bottom inside it.
Can the increased air flow be sucking more oil thru the CCV? (was max of 550 mg/str before cleaning, now >900 mg/str)
Could worn/shrunk valve stem seals cause more oil loss than normal during idle? I spend at least 30 min/day in bumper-to-bumper between long hwy runs. WVO in the CC blew out my rear main seal about 30K ago and I suspect it had the same effect on the valve stem seals.
Any other ideas of where the oil is being lost?
Help please
Help please
