2012 Passat SEL TDI First Oil Change?
jrock
Dallas, TX
Jetta, 2001, Blue, Passat, 2012 Silver
Just picked up my 2012 Passat SEL TDI. Great Car!!!
I remember the old TDI's would require a 5k oil change then 10K there after.
Is it a correct statement that the 2012 Passat TDI is a 10K first oil change. (This is my first new TDI in 7 years).
TDICT
Cheshire, CT
2009 JSW...SOLD..2012 Passat TDI SEL Black on Black...Now Here
First oil change at 10k and every 10k after. You will get a lot of responses warning you about the correct oil. (I think it is 507 spec but someone will correct the numbers). Take their advice. great car, I have 1,500 miles on mine and liking it more every mile.
jrock
Dallas, TX
I found it, it's in the supplemented warranty manual. 10K
TDICT
Cheshire, CT
Good, Now lets see how fast you can get to the 10k mark.
TheGrove
S Central PA (Breezewood)
2012 Passat SEL Premium Opera Red - Dieselgate Fix, KermaTDI Tune, 2004 Passat GLS Northern Green-RIP
I'm figuring on about 8 weeks to 10k for mine. 1 week down, 7 more to go (1554 when I parked at work this am).
pleopard
Calgary, Alberta
2010 Jetta TDI
Please read the manual. You need a 507.00 oil that you will find only comes as a 5W30. 507.00 is backwards compatible with 505.01 if you want to run a 5W30 in your other vehicle requiring 505.01. Some 507.00 oils are also MB 229.51 approved.
TomB
Cle Elum, Washington/Las Vegas, Nevada
2015 Audi TDI Prestige Sport
I can't read the manual yet since my car is just being built. :)
I learned that the 2005 Passats MUST have the 5w40. Used Oil Analysis and visual inspection of the cam proved this weight is necessary for the 2005's, so I am stuck with 5W40 for the 505.01.
I just needed to confirm the new one was 5w30 which means Pentosin Super Performance III for the new car and the Jeep, so only 2!
Thanks for the information.
pleopard
Calgary, Alberta
2010 Jetta TDI
Have you done any Used Oil Analysis to see how it performs?
Actually, I ran the dealer Castrol SLX until the service at 40,000 miles when I switched to the Pentosin. I've run two UOAs out of curiosity so far, and may run one with the Pentosin just to see how things are coming along. However, the $25 charge for the analysis is a bit much to pay for curiosity.
It's not uncommon for the rate of iron accumulation to drop with extra miles on the oil. ppm/1000 miles is how I evaluate the results. This is one of the reasons why it's not a great idea to change oil more frequently than recommended by the manufacturer.
heykw
Orlando FL
fleet
...lol..This reminds me of my encounter with the police on 19 near the new river gorge.
tdi90hp
Canuckland
2011 Golf TDI 6 speed(gone but NEVER forgotten)
5w30.507.10k service.nuff said. drive more worry less. castrol, liquid moly, pentosin, whatever ...its all good
