Glowman
Hello all,
My timing belt broke so I decided to replace my 2005 Jetta Sedan BEW TDI engine with a 2004 BEW engine, both had manual trans. Now the engine cranks but will not start, here is what I've already tried/done;
- I checked all fuses (at door and battery).
- I pulled the glow plugs, turned the engine and NO mist or fuel was present.
- I replaced the G-28 crank sensor with the original one.
- I checked the wire continuity between G-28 and ECM - ok.
- Installed new in-tank fuel pump.
- Fully charged and boosted the battery.
- Did the ignition multi clicks, long cranks, etc.
- One possible clue is that when cranking the engine, the dash oil light does not flash.
- Also, for just a moment I sprayed starter fluid in the intake and the engine did run for a second or two.
I'm out of ideas and really need advise. If you think you can help I would be very appreciated.
Thank you in advance.
