breakfasteatre
asdfs
Yes, as a matter of fact I have. What I did was to drill a hole from the back and used a punch to knock out the broken pin. A replacement pin is about $10 and you can seal up the hole you drilled with a cap screw.Have you ever broken off the slide pins in the caliper carrier? No? Well i did, ***.
