i didnt really mean to make such a long and complex post there. still. it may be hard to follow for a 'beginner' or if your not used to the routine. once you get used to the routine it gets easier. following the steps is the important part, and getting it right. and you should have no problems from this 'end' if you get it right. i probably could find more explanation on subject and keep on going on with a post on it, (and use less punctuation, make it even more difficult to understand.
,jk)
technically the explanation can be complex, as we can all understand, its a basis for what we are doing, trying to accomplish.-getting it right. and theres a lot going on in there. in practice several things can make it (rather) simple. below.
Returned the crank to TDC, same with cam and IP.
so this is incorrect, it was why i posted that difficult and complex post, which may have been hard to understand properly.
in installing head, before this you 1 want to find TDC(crank), as has been suggested, check your crank TDC mark, i used white out, and can add a red felt mark. THEN (important) you want to turn crank back so pistons are even, this is 1/2 a piston stroke, or 1/4crank turn, -back. so 90dg turn back. then do all your work, and leave crank back, leave it alone, so all pistons are even, until your ready for timing steps. otherwise you can easily jam a valve into a piston, or 2, or perhaps 3. and it can be hard to notice.
so to make it simpler. 1 when doing a timing belt, 1 with belt still on, turn motor to TDC, make sure your on #1, knock off cam pulley, disconnect belt. you will now turn crank back the 1/4turn, have that pulley or crank gear marked, so you know aprox where you are @90dg back. you now go on to other work, until your ready to start the timing procedure again.
again with head off, bring crank to TDC, again check flywheel mark, a good suggestion, now turn back so pistons are even. leave crank alone Until you complete all other work, and at/near the last you are ready to set timing.
among other steps i wont cover, you will start timing procedure, 1 check crank is still in proper spot, 90dg back, or 1/4 turn Back. you, among other things, will lock out cam, now turn crank forward to exactly TDC#1, you are now ready for the next steps, and can set the timing.
as i said a neat thing i do is to remove glowplugs, &/or can have injectors out. you wont get compression kick back.
