EOTS
I am considering making a move to replace my '09 Jetta TDI (6M) with '12 Passat TDI.
I stopped by my local VW dealership yesterday to check out on what they have on hand. The sales agent immediately lead me to a Comfortline (SE in the States!) in the lot equipped with leatherette seats, sunroof & TDI engine mated to a DSG. He offered to go for a spin with me.
Once on the raod, I immediately noticed that the DSG behaves totally different from the one in the Jetta I test drove in 2009. This one works almost like a conventional automatic. Up shifts were quick and down shifts were smooth and no jerking as in the first generation DSG's. I was sold!
The freeway run showed that the chassis was built to eat up miles with ease. The ride was quiet with minimal road noise on black top and moderate amount of tire noise on concrete surfaces. The chassis was tuned for ride comfort and yet return a reasonable amount of control on curves and corners. It was an acceptable compromise. The driver seat was fairly comfortable and blind spots are easy enough to check.
The Passast feels bigger than the Jetta. Naturally, its turning radius is larger than the Jetta and caution must be exercised while backing into a parking space or garage. I am guessing the Passat could be as much as 12 inches longer than my '09 Jetta.
In an case, I came away impressed with the car. Yes, the exterior styling is nothing to write home about, but the interior is at least one class above that in the Jetta. It is a comfortable car to spend time in for those long commutes and road trips. The 800-mile per tank cruising range is nothing short of impressive.
I may just make the move within the next few weeks but I have not decided to get the 6M tranny or the DSG which is not an inexpensive option!
Anyone ready to share their test drives of the new Passat TDI?!
EOTS
EOTS
