I have a 2013 JSW (TDI, obviously, with a manual transmission and the sunroof/17" wheels package). I purchased it new in April 2013, and have driven it about 35K miles since then.
See below for lots of details and specific questions, but basically, the car has had many problems, and the warranty is running out. I'm not sure if I should cross my fingers and keep it, or trade it for something bulletproof like a Corolla. Hoping you can share your experiences so I can get a sense of what's to come, both good and bad...
Thanks!
DETAILS:
The 10K, 20K, and 30K services have been completed. 95% of time, I fill it with Shell diesel. I don't regularly use additives, but I've run a few bottles of Stanadyne through it. I always track my mileage, and my lifetime average (calculated, not from the OBC) is 37.6 MPG. I used to commute much further, but now I drive 14 miles (total) per day to work and back. I don't regularly interrupt regen cycles, but it has happened a few times in the past.
I love the car for a number of different reasons, but it, and the various dealers it has been to, have been quite problematic so far. Here's the service history:
- January 2014 - had the intercooler icing issue so had the kit installed to correct that
- January 2014 - dealer did a lousy job on the install of the intercooler kit and had to redo it
- June 2014 - left rear window mechanism broke
- June 2014 - dealer did a lousy job on the window fix and had to redo it
- January 2015 - EGT sensor failure
- June 2015 - check engine light on for DPF and exhaust flap; exhaust flap replaced and dealer said the DPF passed their test and is fine
- June 2015 - check engine light back on for DPF; not sure of resolution yet
The pattern seems to be a shop visit every six months. Other than annoying, this hasn't been a huge deal so far because the car is under warranty. However, I only have 1K miles to go before that's gone. I'm aware that there is a very basic emissions system warranty that covers me for 8 years/80K miles, but the sense I get is that once the bumper-to-bumper warranty runs out, these trips are going to become a fight with the dealer about what is/isn't included.
For what it's worth, I could get a VW 6 year/100K extended warranty for around $2500, but there is a deductible, and many things are not covered. On top of that, I also see this warranty as requiring a lot of fighting with the dealer.
Basically, I would love to keep the car, but won't be able to afford it with this "every six months" regimen once the warranty runs out, especially if it's pricey parts like the DPF that are breaking.
So...here are my questions...
1. Between the EGT sensor failure, exhaust flap failure, and apparent DPF problems, any ideas about the root cause of these gremlins? Is the car just not made for short-distance, stop-and-go driving?
2. What about getting a Ross-Tech VCDS and doing commanded regens to keep the DPF clean? Or fuel additives? Is there anything I should be doing given the type of driving I do and this apparent string of emissions system problems to keep the car happier?
3. Has anyone had similar problems at a similar frequency?
Thanks!
Thanks!
DETAILS:
Thanks!
