Engine Exhaust Flap Limited Warranty Extension
Volkswagen has extended the Emissions Control Systems Warranty for engine exhaust flap replacement under specific conditions to 10 years or 120,000 miles, whichever occurs first, from the vehicle’s original in-service date, for certain 2009 – 2012 Model Year Volkswagen 2.0 L TDI® Clean Diesel Engine vehicles with engine codes CBEA, CJAA and CKRA.
This warranty extension is fully transferable to subsequent owners.
The vehicle’s original in-service date is defined as the date the vehicle was delivered to either the original purchaser or the original lessee; or if the vehicle was first placed in service as a “demonstrator” or “company” car, on the date such vehicle was first placed in service.
What is the Problem
Volkswagen has determined that under specific conditions, certain deficiencies affecting the engine exhaust flap could make the engine exhaust flap susceptible to degraded performance. If this happens, the Malfunction Indicator Lamp (MIL) on the instrument cluster may illuminate due to the presence of specific fault codes caused by a faulty engine exhaust flap. Volkswagen has not identified any vehicle drivability concerns related to this issue.
Please be aware that other conditions (unrelated to the issue described in this bulletin) may cause the MIL in the vehicle to illuminate. Customers should be prepared to cover all diagnosis and repair costs for these other, unrelated conditions.
What does this Warranty Extension Cover
This warranty extension covers only the diagnosis and replacement of the engine exhaust flap.
What is Not Covered Under This Warranty Extension
This warranty extension will not cover:
Any damage or malfunctions caused by installation of non-EPA or non-CARB certified parts, or parts that alter the performance of the engine, engine controls, or exhaust system, such as the installation of engine management components (“chipped” or “tuned” ECMs) not approved by Volkswagen.
Other conditions unrelated to the engine exhaust flap that may cause the MIL to illuminate. These conditions may require repairs that are needed for proper diagnosis of the underlying condition. Any repairs that are (1) necessary for proper diagnosis of these other conditions or (2) required to bring the vehicle’s emission system up to factory specifications are not covered by this warranty extension.
Damage or malfunctions caused by outside influence, such as damage due to an accident, or vehicle misuse or neglect, as well as repairs that are (1) necessary for proper diagnosis of these other conditions or (2) required to bring the vehicle up to factory specifications are not covered by this warranty extension.
Repair Procedure
Refer to Technical Bulletin Instance Number 2031583 for the applicable repair procedure.
Vehicle Eligibility
To determine if a vehicle is eligible for the Engine Exhaust Flap Limited Warranty Extension, check the VIN in ElsaWeb > Vehicle-Specific Notes > Vehicle Data. If the warranty extension is applicable to the vehicle, the "Enhanced Coverage" section of the "Vehicle Data" screen in ElsaWeb will be populated with the warranty extension parameters.
Warranty extensions are just that, warranty not recall. Second TSBs always are xx-xx-xx being all numbers, other info such as warranty circulars, how to set up a scan tool, etc. are xxx-xx-xx the first three digits being letters. Also not everything that shows up in the campaign screen at the dealer is a "recall". Some are just product updates and only apply when new car warranty is still valid.
[steps off small soap box]
Be happy that VW stepped up to the plate and decided to cover a part that they know needs improvement. They could have been cheap and let customer foot the bill. Just sayin'
Jason
