I've been fighting this code since I bought the car a year ago. It runs fine, but the code is annoying me that I can't resolve the issue.
I first changed the Coolant Temp Sensor. A few hundred miles later, the same code came back on.
Months later, I changed both the thermostat and again a new Temp Sensor (both from the dealer). Again, I get the same P0128 code.
I then changed the outside temp sensor. Same story.
Back to the internet, and I came across a forum discussing repinning the connector to the sensor, as the wires get brittle and cause issues. I've visually checked the connector in the past it it looked fine, but today I took the connector off, untaped the wires and discovered the previous owner already had this repinned. (must have been going on for some time).
My questions to the group is can anyone verify which wires go to which pin numbers? I could be barking up the wrong tree, but since I didn't do the repin, I have no way to tell if they did it correctly.
I traced the new wires back to the original and this is how it is currently pinned:
#1 - Pink wire
#2 - Brown/White
#3 - Blue/White
#4 - Brown/Blue
By the way, the temp readout on the dash seems to be steady and always reads 190 after 5-10 minutes.
Thanks in advance for any help, thoughts our ideas.
FYI, It's an 2004 Jetta TDI BEW engine with 140K. I put about 25K on it this past year with no issue other than bad fuel once.
#1 - Pink wire
#2 - Brown/White
#3 - Blue/White
#4 - Brown/Blue
