Thanks, hope to have it together in the next couple of months so we can use it at the Mt Washington Hillclimb (Climb to the Clouds) http://www.climbtotheclouds.com/lookin good any idea when you will have it together?
Yes. We welded the lower universal joint from the mk2 column to the mk4 steering column lower link.Also you are using the mk2 steering rack, welded adapter to the end of the mk4 column?
Much appreciated. We are as eager as anyone else to get it finishedProper.
Nicest build I've ever seen.
No joke.
Thanks, the bore is 0.75" which is the same as the stock mk4 unit 19mmLooks good! Can't wait to see this thing in action.
What is the bore size of the clutch master cyl?
You running an 02J cable shift trans?i have the same shifter in my scirocco, its fantastic.
Things that make the wiring harness a pain:Thanks for the updates.. I don't envy the wiring harness job!
We considered that too but the low-hanging pulley is vulnerable in rally so this is a better solution.Thanks for the updates!
I've actually got an A/C delete on my ALH but it's not as smart as your timing belt tensioner/bracket invention! I've just got a bracket where the A/C lives with a free spinning pulley...
So what control arms will Quantumrallysport be using??b3 correct? I'm planning on useing them in my project.
we are using the passat control arms for now but we are fabricating a stack of tubular control arms with Eric Langbein racing for both of our cars. Should be testing them soon (by soon, i mean after a few weeks working in Kenya and Somaliland and then after my wedding.... Soooo.) pictures will followSo what control arms will Quantumrallysport be using??
