Old September 19th, 2019, 17:04   #1
fitz0520
TDI(s): 05 Jetta
Exclamation Repair or Not Repair Help
Hi TDIers
I need your help! I have a 2005 vw Jetta tdi 1.9l bew that the engine conked out at 287k a few days ago.
I have done some work to make me like the car. Anyone knows how much an engine cost and the installation.
I'm in Suwanee Ga.
Thanks..
fitz0520 is offline   Reply With Quote
Old September 20th, 2019, 06:32   #2
steve6
It really all depends on what conked out means? if something happened with timing belt/head/cam you can have the top end rebuild by a shop for probably 2k'ish(new heard, belt, cam etc). If the bottom end is done, best to find another engine and have it swapped in. Looking at car-part.com engines range from $500 - $2000, plus labor to swap it in.
Call local wrecking yards to see what they have/can get. The cost of a replacement engine can vary greatly and will help you decide if worth while.
steve6 is offline   Reply With Quote
Old September 20th, 2019, 10:52   #3
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Saw in another thread, this guy sells long blocks-BleachedBora
Don't know if he still does, but it's a starting point.
First do a thorough autopsy, yours may be repairable.
Old September 20th, 2019, 12:58   #4
Powder Hound
Powder Hound's Avatar
Originally Posted by steve6 View Post
It really all depends on what conked out means...
This ^^^
A head repair can be done by Franko6. A replacement engine can be had for reasonable cost from Frans.
Until some trouble shooting happens, and you know exactly what needs doing to get it driving again, it is very hard to know what your choices are going to be, and thus be able to make a choice.
Good luck,
PH
Old September 25th, 2019, 12:52   #5
Nevada_TDI
Does the engine still turn over, and/or does the inter cooler have a lot of oil in it?
_______________
2001 Jetta GL TDI, Tinted, Vented, No Kitty, EGR-ectomy, TDTuning, HIFLO .216's, TurboLabAmerica Hybrid 15-17/56, VCDS Hex+CAN, S-B Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Koni Orange, New Paint. Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old September 25th, 2019, 13:40   #6
BobnOH
not-a-mechanic
Yes, so you need a good assessment of the damage. Most of us are of the fix it school.
Old October 1st, 2019, 20:49   #7
sharpfork
TDI(s): 2001 Jetta
Default Me too- 2001
Iím in a similar boat with a 2001.
Is there a thread or a guide I can use for reference? Iím not sure where to start.
Originally Posted by Powder Hound View Post
This ^^^
Frans?
Thanks!
sharpfork is offline   Reply With Quote
Old October 2nd, 2019, 05:10   #8
300D
Fuel Economy: 43.5mpg
Frans?
Thanks!
Other more knowledgable people will probably chip in with lots of good info, which is the norm on this forum, but if you really don't have any idea where to start, a tried and true guru near you might be a good place to start:
https://forums.tdiclub.com/showthread.php?t=130044
The generally acknowledged rule is that regular mechanics just don't know what is up with these cars. I met my car's orginal owner and he told me that his mechanic had advised selling at 140,000 miles as it wasn't worth it to repair. My car currently has 265,000 and going pretty strong.
Frans is a trusted vendor on this site and sells all sorts of TDI parts:
https://forums.tdiclub.com/showthread.php?t=434593
300D is online now   Reply With Quote
Old October 2nd, 2019, 05:27   #9
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
I have a good, used, 185k mile BEW long block for sale. I know its history since the day it was unloaded from the transport, so I know it is in good order.
oilhammer
www.cardocautomotive.com
Need A/C repair POWERSTROKE VW MKIV-A4 TDIs (VE and PD) 3 November 19th, 2013 20:25
Scratch repair help emerscape VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 6 September 30th, 2013 08:39
Repair, do it or not? blingem TDI 101 32 April 26th, 2013 14:28
What is this and how do I repair it? Midnight Rider VW MKV-A5 Golf/Jettas 5 September 13th, 2009 00:03
Repair or Not Repair Xavior TDI 101 2 September 10th, 2009 10:58
Page generated in 0.16556 seconds with 11 queries
[Output: 93.00 Kb. compressed to 79.79 Kb. by saving 13.21 Kb. (14.21%)]
