Old September 18th, 2019, 14:25   #1
Fasteddie10
Default Does deleting the EGR on BEW effect cold weather operation?
My new EGR pipe for my new Garrett GT1749 does not fit well. I have a small leak that is whistling. Drivers side flange was off by 1/2 bolt hole, was a wrestling match even with the cooler bolts loose. Now I am thinking about a delete kit. Cleaned up the intake, was dirty but not as bad as a number of photos that are posted.
My concern is engine heat in the winter, a few people say to leave it due to egr helping it warm up. Have 2 BHWs with a delete kit, no heating issues on them. It does get below zero here. You can watch the temp gauge go down while idling when below zero. But heats right back up while driving. Being a manual, it uses so little fuel at idle.
Fasteddie10 is offline   Reply With Quote
Old September 18th, 2019, 14:29   #2
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
It affects a little, noticeable for some, not for others.
BobnOH is online now   Reply With Quote
Old September 18th, 2019, 14:58   #3
Mike_04GolfTDI
Mike_04GolfTDI's Avatar
The manual transmission version has the three glowplugs in the cooling system to help with warming up. So perhaps EGR delete is less of an issue with those.
I haven't noticed any problems in the winter. Seems to warm up just as slowly with or without EGR.
2004 Golf GLS TDI 5-spd, DC Stage 1 Clutch, Evolution Atlas Skid Plate, Malone Stage 4 Tune, GT1749VB Turbo, 3 bar MAP
Mike_04GolfTDI is offline   Reply With Quote
Old September 19th, 2019, 08:45   #4
gforce1108
gforce1108's Avatar
Fuel Economy: Jetta: 44.5 summer / 47 on snows
Mine is quite slow to heat up - at least 10 minutes of driving. I have not checked if the coolant glow plugs work and I have no hood insulation. I changed the thermostat to see if it would help and it would not. I have to get on it hard at least once to get the heat going and most of my winter driving shows coolant temps in the 170 range (dash gauge reads fine, SGII shows low temps). By contrast - my 03 with working EGR (no hood insulation either), starts to get warm within 2 minutes of light driving.
EDIT - adding pipe insulation as a grill block does help my 04.
I hate rockauto.com http://forums.tdiclub.com/showpost.p...&postcount=236
04 Jetta GLS 5sp - EGR delete, RC3, VNT17/22, 3" turbo back exhaust & 2.5" FMIC+PD150 intake. SBC Stage 2 Endurance w/SMF. Eibach lowering springs
gforce1108 is online now   Reply With Quote
Old September 19th, 2019, 12:34   #5
scurvy
Good Ol' Boy
scurvy's Avatar
TDI(s): 2006 Golf
Fuel Economy: ☠☭
Install pipe insulation and a Zerostart heater, you'll never notice the difference.
FWIW, I use both in the winter and have my EGR tuned out. It does get a little chilly in my corner of Illinois and my commute isn't a long highway one anymore.
Your thermostat still isn't working correctly if the coolant doesn't get above 170F... you need to replace it with one that does work, and you should verify it in a pan of hot water before installing it.
I used a Stant Superstat with OK results (got up to temp quickly, but more variation in coolant temps), also an OEM Mahle with good results.
If you post a question, post your solution!
mk4 front wheel bearing | scurvy winter front | VCDS in Chicago, IL USA
You are entitled to your opinions but not your own facts.
scurvy is offline   Reply With Quote
Old September 19th, 2019, 12:38   #6
KrashDH
TDI(s): 2002 Golf
Like all diesels, they aren't going to warm up just idling in the driveway. They need to be under load to heat up. It may be a matter of a few extra miles before it's up to operating temp, but it's nothing to sweat.
KrashDH is offline   Reply With Quote
Old September 19th, 2019, 13:23   #7
gforce1108
gforce1108's Avatar
2 thermostats (original and replacement from idparts) - same temps. Lower radiator hose is cold.
Old September 19th, 2019, 13:58   #8
Genesis
Fuel Economy: 53/48/42
I've had mine, at a train crossing in the winter while waiting for said train, lose enough heat to go from normal operating temps and plenty of cabin heat to COLD AIR out of the heater and the needle barely off the cold peg! Yes, these engines idle quite cool and in the winter, with no load.....
Mine is an ALH but it DOES have all of its stock bits on it, including the EGR cooler....
Genesis is online now   Reply With Quote
Old September 24th, 2019, 09:17   #9
Votblindub
Votblindub's Avatar
My white car isn't deleted and it's on the cooler side during the winter, even with the radiator blocked off. The seat warmer helps. The frost heater helps, but it's heater is nowhere NEAR the one in my Audi.
Sprint 520 Nozzles, 2.5 inch catless mufflerless BuzzKen exhaust, Malone stage 3 chip, 01M, Frostheater Full details
Full details
FB page for wagon lovers I have VAGCOM/VCDS
Votblindub is offline   Reply With Quote
Old September 24th, 2019, 10:07   #10
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
FWIW, the BEW (and the BRM) both have EGR cooler bypass flaps. Which means, when the engine is cold, the heat transfer won't be as much through the EGR cooler anyway. Unlike the ALH and BHW, where the EGR is ALWAYS passing through the cooler when the EGR is on.
So I think the difference in warm up with or without a functional EGR cooler on the BEW may not be as noticeable as on some other TDIs.
That said, it seems like the PDs do some trickery with maybe the electronic intake flap and bigger EGR passages as well as the ability to run more fuel and boost (so, more power) that they seem to warm up a little quicker than the VEs do anyway. At least, that has been my experience.
Because otherwise, the ALH and BEW have virtually the exact same cooling system, and volume (more or less) same thermostat, and are moving essentially the same car. I do not know if it is just the less efficient (fuel use wise) of the PD100 vs. the VE90 or what.
oilhammer
www.cardocautomotive.com
Old September 27th, 2019, 08:28   #11
scurvy
Good Ol' Boy
scurvy's Avatar
TDI(s): 2006 Golf
Fuel Economy: ☠☭
Did you verify that they open at the correct temperature before installing them? There have been lots of complaints in the last few years about brand new, non-functional thermostats, even OEM.
It's either the water pump, thermostat or a restriction in the system. Cooling system is pretty simple on these cars.
Old September 30th, 2019, 06:58   #12
gforce1108
gforce1108's Avatar
I did not - but I do know it's not stuck open since the lower hose is cold. When the outside temps are higher, the car runs at the correct temp. I just replaced the thermostat on my 03 and did verify that it opened correctly (the old one was stuck closed causing overheat on very hot days).
A higher temp thermostat is on my to-do list for the 04. I will test it before install and also test the one I remove.
Cold Weather operation tdibichons VW MKIV-A4 TDIs (VE and PD) 2 October 4th, 2004 12:12
What to Know - Cold Weather and Diesel Operation? ctsoh TDI 101 16 September 25th, 2004 10:59
Cold Weather TDI Operation Puffin VW MKIV-A4 TDIs (VE and PD) 21 February 18th, 2004 08:46
cold weather biodiesel operation (take three) nh mike Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 96 November 1st, 2002 05:48
cold weather operation Terry Munday Fuels & Lubricants 3 August 27th, 2001 00:55
Page generated in 0.17052 seconds with 11 queries
[Output: 117.22 Kb. compressed to 99.44 Kb. by saving 17.78 Kb. (15.16%)]
