Den
- Joined
- Apr 15, 2001
- Location
- Central Fla.
- TDI
- 2001 Jetta Baltic Green & 2015 Passat SE TDI 6 spd. auto.
Have just completed a total rebuild of my cylinder head, valves, guides, seals and lifters. Have the engine assembled, timed and the serp belt on, new coolant and now having issues trying to start. Had all the fuel lines from the pump to the cylinder head removed so they where dry at re assembly. Having the wife crank the engine while I break the fuel lines at each injector waiting for fuel then tightening the nut. Did notice that I didn't have much pressure/ fuel when I did this. So my question is how long will it take for the engine to fire after this is done? I have cranked it quite a few times and still no fire. How long should this take for the engine to fire.?
