Old September 21st, 2019, 09:07   #1
Insane
TDI(s): MK7 Golf
Default DEF tank mounting bolt size.
Found this today,
https://imgur.com/6rUMhe7
I was hoping someone could tell me what bolt size goes there. My mechanic isn't answering, don't blame him, it's Saturday. It's the rear most, passenger side, mount on the tank.
Thanks!
Edit: Mechanic answered! yay!
Rear bolt is a M12-1.5, the 2 forward bolts are M8's
Insane is offline   Reply With Quote
Old September 21st, 2019, 14:15   #2
Nuje
One of the reasons I keep a wide variety of old bolts and nuts on hand - never know what you might need for some oddball reason.
Just looking at it, I'd guess an M8; no idea of the length, though. Probably a washer or good-size shoulder on the head of the bolt, too. And (from what happened), probably a dab of blue loctite.
His ride: 2015 GSW SEL TDI with MIB2, Active Info Display, DSG tune
Her ride: 2016 A3 e-tron
His other ride: 2015 Giant Propel SL Di2
Nuje is online now   Reply With Quote
Old September 21st, 2019, 14:40   #3
JM Popaleetus
JM Popaleetus's Avatar
Looks like an M8x25.
2015 VW Golf TDI SEL (DSG, Lighting and Driver Assistance Packages, Tornado Red/Titan Black)
2007 GMC Sierra 2500HD Classic (Duramax LBZ, SLT, Extended Cab, Summit White/Ebony)
2013 VW Passat TDI SEL Premium Buyback
2010 VW Jetta TDI Buyback
JM Popaleetus is online now   Reply With Quote
Old September 22nd, 2019, 21:55   #4
Nuje
The one on the other end (#3 in the diagram) is an M12x1.50 50mm - which is same spec as the big honkin' bolts that screw into the engine support bracket when doing a timing belt job.
So yeah - M8x25 seems like the more likely option.
Old September 25th, 2019, 19:36   #5
Insane
TDI(s): MK7 Golf
my bad, it's M12-1.5 for the rear hole. That's the one I was missing.
Old September 25th, 2019, 19:37   #6
Insane
TDI(s): MK7 Golf
The M8's are the 2 forward most bolts. I was missing the M12. Thanks for the picture.
Using the DEF tank for diesel mxtdiguy VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 16 August 9th, 2018 15:41
Bell Housing Bolt Part # or Bolt Size AHU Engine specialed1995 TDI 101 1 December 7th, 2016 22:18
PSA: Diesel does not go in the DEF tank whitedog TDI (Diesel) Emissions 3 January 13th, 2016 07:06
20,000kms so far on first DEF tank... spicy_red VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 8 September 14th, 2015 07:52
bolt size please, alh cam sprocket bolt 19mm AARodriguez Corp. TDI 101 3 October 9th, 2013 10:25
Page generated in 0.13928 seconds with 13 queries
[Output: 75.97 Kb. compressed to 66.63 Kb. by saving 9.35 Kb. (12.30%)]
