Old September 19th, 2019, 14:17   #1
kfhoffman3
Default 13 Passat TDI Turbo rebuild/replace DIY advice needed
Hello all, hoping I can get some good advice on how to best proceed from the situation I find myself in.
TL;DR - Sorry it got long... I blew my turbo and need to find a decent rebuilt one or a place to get it rebuilt since I am out of warranty and doing it myself.
I have a 2013 Passat TDI SEL (NMS/CKRA it's a US car) with 138k miles and of course the turbo just failed last week.
On my way home from work about 15 minutes into my drive just accelerating from a stop sign I had sudden loss of power, blinking glow plug light and turbo underboost code. I limped it home.
The dealership refused to service it under the extended warranty/TSB since that was only good to 120k and they wanted $5k to replace it - they verified the turbo was bad by inspection with a borescope down the intake.
I decided to do it myself since over the years I've done a number of engine/trans swaps, engine rebuilds, etc but mostly on older cars and I'm familiar with turbo systems on gas cars (my other car is an 88 Supra turbo) so I didn't think it would be too bad but this is my first real foray into the VW's and diesels.
After some grief removing the DPF and having to pick up some special tools I have the turbo off - the intake impeller is seized in the housing and the exhaust impeller is basically flopping around.
There was about 3/4 of a quart of oil that came out when I detached the front intercooler pipe but none on the exhaust side or in the DPF itself.
This one is the Borg-Warner (03L 253 056 E V 500 on the tag).
I planned to order the turbo online but the main place I see them is from is TurbochargerPros / BuyAutoParts and the reviews don't look too good, they sound like Chineese knockoffs - even if they are warrantied I have no desire to do this labor again.
Junkyard is out of the question as I will probably get another part with the TSB problem.
The dealership said they could not find anything with that part number but looking it up by VIN they show 03L 253 010 J and there is literally one in the USA at some dealer in Ohio and they want $1667.52 for it; ECS has one for $1400.
Found one by the new part number on IDParts but I don't know anything about that company.
SO here's where I could use some advice:
Is that part number a legit replacement for the existing part number?
Does anyone know of a reputable source of rebuilt turbos for this car that are preferably under $1,000?
I called a few local diesel shops and none will rebuild it, probably because it's a VNT but as soon as I said it was off a VW they had no interest.
Is there a known good place to get these rebuilt in a reasonable timeframe, preferably in the Midwest (I'm in Wisconsin).
I'm still making payments on this car and I'm paying out of pocket for a rental until I get it back in action so the quicker I can get this done the better.
Last but not least, if anyone has any other advice on the replacement procedure I'd greatly appreciate it!
Thanks for reading this far, the post got a bit long winded but I wanted to cover everything I could think of.
Looking forward to some good news, so far this whole situation has been bad.
kfhoffman3 is offline   Reply With Quote
Old September 19th, 2019, 14:34   #2
calimustang
Sent you pm.
2011 JSW TDI retired and buyback w almost 300k miles.
2015 Passat TDI DSG
2014 JSW TDI DSG
1989 Mustang GT and 89 Ocala FL SSP coupe 5.0 5MT
calimustang is offline   Reply With Quote
Old September 19th, 2019, 15:03   #3
Here's the turbo: https://www.idparts.com/advanced_sea...s=turbocharger
We have both reman and new. I think either are a pretty good deal, especially compared to the quote the dealer gave you. Given what the reman turbo costs I don't think it would be worth your time to attempt to rebuild the one you have.
2002 Jetta wagon, 393K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 289K; '99.5 Golf, 260K; 2011 335d, 61K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old September 22nd, 2019, 17:53   #4
kfhoffman3
Thank you, I ended up ordering the turbo from IDParts and will be installing it next weekend.
Only part I couldn't get from IDParts is the oil pump, which the TSB recommends replacing and is probably due anyway at 138k.
It appears the oil pump driveshaft is starting to wear on the edges of the 6 faces on both sides.
Maybe I'll make a write-up of my notes on doing this for the forums if anyone has interest in that.
Old September 24th, 2019, 04:39   #5
c3kTDi
TDI(s): 2015 Passat
Yes. Interested in how your turbo swap goes, as well as the oil pump.
c3kTDi is offline   Reply With Quote
Advice needed: rebuild all suspension bushings/wearable cuban11182 VW MKIV-A4 TDIs (VE and PD) 4 June 15th, 2019 09:34
Need advice: Replace or rebuild injection pump? Flimzy TDI 101 78 October 31st, 2013 08:57
Why does this turbo rebuild kit have 13 nuts? honesttussey TDI 101 1 September 28th, 2008 18:16
DIY injection pump rebuild? '97 Passat jconnelly TDI 101 3 March 5th, 2007 15:41
Help- Pics needed to rebuild 97 Passat TDI burban864 VW MKIII-A3/B4 TDIs 3 May 23rd, 2005 18:49
Page generated in 0.15176 seconds with 13 queries
[Output: 72.02 Kb. compressed to 64.26 Kb. by saving 7.76 Kb. (10.78%)]
