Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old January 28th, 2019, 17:02   #1
Strider17
Default MK4/MK5/MK6 Parts Clearout - CHEAP!!!
All Parts are Located In Hamilton Mountain
Willing to ship smaller parts at buyers expense
Have Pictures of all the parts but there are too many to post…so just message me if you want to see what the part looks like you’re interested in.
TEXT at 905 921 6015
Alpine CDA117- USB/AUX/Cage/Trim/Remote – Sounds amazing – 60
MK4 Aftermarket Radio Harness – x3 – 5
VW Vortex Licence Plate Cover – 5
Universal Rubber Mats Front and Rear – 10
Clutch Disk = TSI i think??
Mk5/MK6
09G Automatic Transmission – 60k - 300
09G Automatic Torque Converter – 60k – 150
09G Automatic Transmission Cooler – 10
09G Automatic Starter – 60
09G Transmission Control Module - 20
TSI/09G Passat ECU – 06J 906 026 AG CCTA – 100
TSI/Manual GTI ECU – 1K0 907 115 AP CCTA – 100
MK5/MK6 TDI Complete Clutch Kit w/throwout bearing - 200
Driver and Passenger Axles for Automatic Transmission – 30 each
MK5/MK6 TDI or TSI Alternator – 30k - 150
MK5 Jetta Complete CatBack Exhaust – 100
MK5/MK6 Complete Independent Rear Suspension – 100
B6 Passat Trunk Plastic Liner – 40
B6 Passat Trunk Roller to hide trunk - 40
MK5/MK6 – ST Coilovers – 30k – 400
MK5 Front Control Arms – 25 each side
MK5 Rear Calipers – 30 each
GTI Monster Mats Front and Rear– 75
Cloth Mats Front and Rear – x4 – 15
Stock Front Struts - 40
Stock Rear Shocks - 30
Stock Front Springs – 30
Stock Rear Springs for Wagon/Sedan - 30
“Half” Plastic Skid Plate (has small crack – Perfectly usable) – 10
Complete Plastic Battery Box – 25
Cloth Battery Blanket – 10
CJAA TDI Engine Cover – 25
CJAA TDI Intake Manifold – 60
CJAA TDI ASV Valve x2 – 40
CJAA TDI EGR Valve – 40
CJAA TDI EGR Cooler – 60
CJAA DPF EGR Cooler Filter/Piping – 30
CJAA Complete Oil Cooler – 40
Front Jetta Wagon Complete Carriers – 25 each
Front Jetta Wagon Calipers – 30 each side
MK5 TDI Half FIS Cluster x2 – 30
MK5 TSI FULL FIS Cluster – cracked plastic - 30
MK5 ABS Module - 40
MK5 Hand Brake Cables – x6 – 5 each
MK5 Driver Side Mirror – Glass Only – x4 5 each
Mk5 Passenger Complete Side Door Mirror – missing turn signal – 10
MK5 Driver Complete Side Door Mirror – missing turn signal - 10
MK5 Inner/Outer Tie Rods – 10 each
MK5 Front Sway Bar links – 5 each
MK5 Rear Sway Bar Links – 5 each
MK5 Rear Upper Strut Mounts w/Bump Stops – 5 each
MK5 Front Ball Joints – 5 each
Heater Core – 15
MK5 Auxiliary Heater for TDI – 10
MK5 Master Drive Window Switch w/trim and Side Mirror Control – 15
MK5 Jetta Wagon Rear Wiper Motor – 25
MK5 Blower Motor – x2 – 15
Mk5 Radio Trim x2 – 5
MK5 Coin Tray (under radio) – 5
MK5 Heater/Seat Controls – x2 – 10
Mk5 5speed Shifter Knob – 5
MK5 Wiper/Signal Stalks – x2 – 15 per set
MK5 Inner Chrome Door Latch w/open and close Buttons – 5 each
MK5 Dash Side Vents – 5 each
MK5 Front Center Dash Vent w/Hazard Switch - 10
MK5 Mud Guards x3 – 10 per set
MK5 Passenger Side Engine Mount – 10
MK5 Driver/Passenger Door Window Regulator – complete – 20 each
MK5 Wiper Linkage w/motor – 35
MK5 Front Door Inner plastic covers (covers door lock module – 5 each side
MK5 Master Window Switch for Driver Door – 10
MK5 Headlight Switch – 5
MK5 Gas/Trunk Door Switch Combo – 5
MK5 Coolant Reservoir Cap – 5
MK5 Ignition Switch x2 – 10 each
MK5 Door Crash Sensors – 5 each
MDI 30 pin Cable – 5
MK4
Bosch MAF Sensor w/housing – less than 1000km on it – 60
Passenger Side Engine Mount w/Steel Inserts – x2 – 20
Driver Side Transmission Mount w/Steel Insert – 20
Passenger Side Fender – no rust - needs Paint - 20
Wiper Linkage Tray – Under Windshield – 25
Climatronic Display Control – x2 – 10
Front Silver Ash Tray – 5
Under Radio Pocket - 5
Rear Center Console Cup Holders (newer style) – 10
TDI ALH Thermostat Housing x2 – 5
Brake Master Cylinder w/reservoir – x3 – 10
Radiator Fan Control Module - 10
GTI Wiper Stalk w/reset button – 5
Rear Caliper Carriers – 5 each side
Rear Stub Axle - x2 – 5 each
EGR Cooler/Piping – 40
Black Plastic Upper Strut Caps x4 – 5 each
Power Steering Caps x3 – 5 each
Dashboard Switches – ASR, Seats, Hazard etc – 5 each
TDI ALH Injector Hard Lines – 5 each
Front Fender Side Markers Clear – 5 each
TDI ALH Glow Plugs used – 5 each
Front Driver/Passenger Bumper Amber Marker – 5
MK4/MK5
Passenger Side Door Lock Module x2 – not tested – 10
Transmission Dust shield – x2 – 5
Sway Bar Bushings – 10 for both
Licence Plate Holder – 5
Trunk Latch – 5 each
Gas Tank Cap x3 – 5 each
Windshield Wiper Motors – x4 -5 each
Wiper Hood Spray Nozzles – 5 each
MK4 Auto to 5Speed Swap – 100 for all
Includes:
Clutch Pedal
Brake Pedal
Gas Pedal
Power Steering Line
Clutch Pedal Line
Shifter Linkage
Slave Cylinder
Axle Heatshield Cover
Switches
Relays
Wiring
Brackets
Nuts/Bolts
MK5 Jetta/Wagon Doors - Dark Blue color
Front passenger door - sedan or wagon
Rear passenger door - sedan
Rear driver door - wagon
Doors are complete
80 each FIRM! - wont find a complete door for 80 anywhere
Colt Cam Stage 2 Billet PD Camshaft for BRM VW Mk5 – 2006 - 800
Bought a deluxe kit from KermaTDI
put in the car, drove for 1000km then car got rear ended parked on the side of the road
CAM KIT INCLUDES:
Black Nitride Cam Followers/Lifters
Camshaft Bearing Shells
Bearing Journal Cap Bolts
Injector Rocker Bolts
This kit goes for 1100 usd.
Everything is practically new
BRM INJECTORS WITH 77k (not Miles) – 800 obo
Stored in diesel
Not sure what these go for but I know pd150 injectors sell for 2300 usd
So I’m selling these oem stock ones for 800 obo
Strider17 is offline   Reply With Quote
Old February 11th, 2019, 03:34   #2
Strider17
clutch kit
front struts
front springs
SOLD
Old February 11th, 2019, 18:51   #3
Strider17
alpine radio
vwvortex plate frame
SOLD
Old April 1st, 2019, 18:36   #4
Strider17
colt camshaft sold
Old September 22nd, 2019, 17:47   #5
Strider17
bumpp
MK4/MK5/MK6 Parts Clearout - CHEAP!!! Strider17 Private TDI Items for Sale/Wanted 38 October 15th, 2019 16:43
FS: MK4/MK5/Mk6 Parts/Car for TDI/TSI - Located In Canada Strider17 Private TDI Items for Sale/Wanted 0 June 27th, 2018 11:00
FS: MK4/MK5/Mk6 Parts/Car for TDI/TSI Strider17 Ontario 0 June 27th, 2018 10:59
MK4/MK5/MK6 Clearout! TDI 1.9L/2.0L - CHEAP!! Strider17 Private TDI Items for Sale/Wanted 13 December 21st, 2016 19:15
FS: Garage clean out of MK3/MK4/MK5 and MK6 parts! Vw NewF Ontario 22 October 2nd, 2013 14:47
Page generated in 0.14355 seconds with 13 queries
[Output: 72.29 Kb. compressed to 64.74 Kb. by saving 7.55 Kb. (10.44%)]
