Go Back   TDIClub Forums > VW TDI Discussion Areas > OBD Scanners
OBD Scanners Discussions on using On Board Diagnostic (OBD) scanners/ Diagnostic Equipment related to TDIs
Old September 22nd, 2019, 09:11   #1
hangman
Fuel Economy: 50 Highway
Default Is this the correct forum: Ross tech Cable & VCDS error codes
Hey Folks,
First of all I am not sure if I posted this in the correct forum.
I am here only intermittently. have a 2013 VW Jetta Sportwagen TDI with 107,000 miles
I did not drive the car for about a week. Today I got a check engine light. So I hooked up my Ross-Tech HEX-V2 cable and ran the VCDS program.
Here are the codes which came up:
008213-Intake manifold flap position sensor (Bank 1)
P2015-003 Implausible signal- MIL ON
Fault priority 2
Fault Frequency 7
01038 Central locking Thermal Protection
000---Intermittent
Fault Priority 6
Fault Frequency 2
What do I have to do to fix these problems?
Thanks for any helpful advice
hangman is offline   Reply With Quote
Old September 22nd, 2019, 12:31   #2
Lightflyer1
Lightflyer1's Avatar
If you have had the fix, take it to the dealer as they should fix this under the extended warranty. Central locking is an intermittent fault and should clear when they fix the other. If it comes back and sets the light again they should fix that as well. Unless it is some known error already.
Old September 22nd, 2019, 14:46   #3
JSWTDI09
JSWTDI09's Avatar
If your car has not had "the fix" (IOW: no warranty), look here:
https://www.dieselgeek.com/collectio...5-manifold-fix
The P2015 is an easy known fix.
The other fault is "intermittent" and most faults of this type are just cleared and they usually do not come back. If it does come back, deal with it then. It is not the source of your CEL.
Have Fun!
Don
2009 Jetta SportWagen TDI (gone but not forgotten)
2018 VW Tiguan SE (I wish it was a TDI)
JSWTDI09 is online now   Reply With Quote
Old September 22nd, 2019, 15:52   #4
hangman
Yes, They did the emissions modification on my vehicle
Old September 22nd, 2019, 16:12   #5
Lightflyer1
Dealer then as it is covered. The Dieselgeek fix above could be installed afterwards to insure it doesn't happen again. Easily installed or removed if needed due to later service. Don't want them to deny warranty due to anything, so it may be best to remove before they look at it if that is needed. $65 worth of insurance after it is fixed.
Old September 26th, 2019, 08:01   #6
hangman
I want to thank everyone for helping me with this situation.
It was covered under the extended emissions modification warranty
They replace the intake manifold
Thanks again!
Old September 26th, 2019, 12:31   #7
Lightflyer1
Spend the $65 and install it now and never have to worry about it again.
Old September 26th, 2019, 15:02   #8
JSWTDI09
JSWTDI09's Avatar
Yeah, what a waste. Dealers make a lot more money replacing the whole manifold rather than just installing a simple fix.
Lightflyer is right. The Dieselgeek bracket not only fixes the problem (if you already have it), it also will prevent it from ever occurring again. Your new manifold has the same cheap plastic part that will wear out again. If you plan on keeping the car $65 is cheap insurance.
Have Fun!
Don
Ross Tech VCDS cable jprich7 Private TDI Items for Sale/Wanted 3 July 28th, 2019 06:56
VCDS (Ross Tech) Cable & 2 Micron Filter Kit umrpunter Private TDI Items for Sale/Wanted 6 October 18th, 2018 11:41
Ross Tech Micro-Can VCDS cable Sbeghan Private TDI Items for Sale/Wanted 4 August 6th, 2017 18:42
Ross-Tech VCDS cable Bigwhitebeast Private TDI Items for Sale/Wanted 4 March 29th, 2015 03:43
Ross Tech VCDS cable tleader Private TDI Items for Sale/Wanted 2 November 13th, 2014 04:54
Page generated in 0.15338 seconds with 13 queries
[Output: 86.77 Kb. compressed to 74.58 Kb. by saving 12.19 Kb. (14.05%)]
