O
oly
Guest
I'm using Metalnerd's Rear Brake Reset Tool but it is not working to compress my original rear brake caliper on a 2000 VW Golf GL TDI. Does this mean that there is a problem with the rear brake caliper?
I'm using the directions that came with tool to locate the tool in the caliper. I lubricated the tool threads with WD-40. I turned the jackscrew with my fingers until the tool was firmly in place like the picture in the instructions. But I'm unable to compress caliper piston more than 1/4 turn of the tool handle before the piston seems to lock up. The piston is nowhere near as compressed as the instruction sheet picture shows. Also, I tried compressing by just turning the jacking screw and the piston does not compress. I turned the jack screw only until it squeezed its teflon washer out then gave up.
Has anyone had this problem before?
