03TDIJettaWagon
Hey party people,
I have an 03 tdi jetta wagon with a leaking fuel injector pump.
I bought the seals from dieselgeek and watched their youtube videos closely to not mess up the job....But I think I did.
After getting everything back together, I went to turn the engine over by hand from the crankshaft pulley bolt and I got 2 or 3 good turns and then BAM! Kiss of death. Won't turn over anymore....
I never primed the fuel injector pump with my mighty vac after the install and have not tried to start the car. Do I need to prime the fuel pump first? I'm worried if I do that it could move the shim to a worse location.
Is it possible that the fuel shut off solenoid could do this? The spring in that plunger did not want to stay in. Not sure if it is as it should be...
Are there any other options of things that could stop the engine from turning like this or did I for sure drop that little shim by the cam plate?
If so....Any ideas on the best way to get it back? Is the shim metal? Could I try a magnet? Do I for sure have to take the whole pump out of the car or could I just pull the head out and get it that way?
Any videos or more info on how to get the shim back?
Also what versions of fuel pumps can I put in this car? Would a fuel pump off of a gas VW work on my 03 jetta tdi?
Thank you for any little help.
