st50maint
- Joined
- Nov 25, 1999
- Location
- Long Island, New York
I took my 2006 Jetta to the dealer for a glow plug replacement under warranty. I considered doing it myself but heeded the warnings about the possibility of the ceramic element shattering inside the head. I showed them the printout from Vag Com and told them that number 2 glow plug measured 147 ohms as opposed to the 0.7 ohms on the other 3.
I picked the car up after service hours so I did not have a chance to question them.
This is exactly how my invoice was written:
01230022 TECHNICAL CHECK
8571 WO3 0.35
82311950 GLOW/SPARK PLUG REMOVE+REINSTALL
8571 WO3 0.30
1 N-105-916-04 GLOW PLUG
82201900 HEATER REMOVE AND REINSTALL
8571 WO3 2.20
20601 GLOW PLUG CUSTOMER STATES / CHECK ENGINE LIGHT IS ON. TECH CHECKED DTC’S, FOUND CODE FOR OPEN CIRCUIT GLOW PLUG CYLINDER 2.
(P0161B) TECH REMOVED HARNESS, FOUND OK. TECH CHECKED GLOWPLUG, FOUND FAULTY. TECH REMOVED BUMPER, HEATER, REMOVED AND REPLACED GLOWPLUG TO CORRECT, RESET CODES, REPAIR COMPLETE.
Does the bumper and heater removal make any sense?
8571 WO3 0.35
8571 WO3 0.30
8571 WO3 2.20
