Old July 10th, 2018, 20:57   #1
svseeker
Default Bellhousing for 95' 1.9 AAZ TD
Howdy. Accept my apologies because I barely know enough about VW engines to ask this question. But we have what I believe to be a 1995 VW 1.9 AAZ turbo diesel engine out of a Passat that we have installed in a jet boat. We make an adapter plate so the drive shaft is bolted onto the back of the flywheel, and then fabricated a mount for the starter which would normally be bolted onto the bell housing. The problem is that the starter frequently hanging up after the engine starts and it's not very long before we have destroyed the gear teeth on the starter. We have tried but have not been successful correcting the problem with our fabricated starter mount, so we have decided to try an locate a transmission that we can then cut away the bell housing portion so we can more accurately mount the starter. The problem is that we are not sure which cars or years might be suitable matches for our engine. We need to know the various makes and years that will fit this engine and be assured that the starter will align properly with the flywheel. Hopefully there is a number of modes and years that will fit.
Here is a link to a video that shows the engine being installed. Skip to 4:50
https://youtu.be/ef3fKUV9Ka8?t=294
And thanks for your assistance. --Doug
svseeker is offline   Reply With Quote
Old July 11th, 2018, 02:51   #2
mogly
The B4 Passats all used the O2A series transmissions. I'm confident the O2Js also used this same starter. Bosch SR0408X is the part number.
mogly is offline   Reply With Quote
Old July 11th, 2018, 04:13   #3
AndyBees
AndyBees's Avatar
Doug
The bell housing bolt "pattern" on VW in-line 4 cylinder engines has the same pattern all the way back to 1974 and including up thru 2006 and maybe later, gasser or diesel! And, the starter Mogly listed will work ...
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
AndyBees is offline   Reply With Quote
Old July 11th, 2018, 16:45   #4
svseeker
That is good news. If you know, have there been any changes in location of the fly wheel that would cause the starter to be located too far forward or back? I have an offer for a 99 Beetle down in Texas. It just seems strange that it might fit.
Old July 11th, 2018, 19:19   #5
AndyBees
AndyBees's Avatar
The flywheel from any model in those ranges will work on any engine.. no changes. The teeth on the flywheel are in the same place in relation to the start engagement. However, the flywheel used on the early models (MK1) is substantially different. A late (MK4, MK5) model flywheel will bolt up and work perfect on the older engines but can only be used in the later transmissions as the clutch operation is also entirely different in the older set-ups.
VW 1600 Td, VW 1900 TD AAZ For Rabbits,Vanagon, Samurai conversions vw diesel king Vendor & GroupBuy items for sale 0 June 8th, 2017 10:17
AAZ - Oil supply and return lines for AAZ '95 TD Turbo charger jlagos22 Other VW Group TD(I)s 2 April 14th, 2016 14:44
Block Heater for '95 Passat B4V AAZ Green Waters VW MKIII-A3/B4 TDIs 2 January 7th, 2011 18:05
95 golf td aaz br8keit VW MKIII-A3/B4 TDIs 5 October 24th, 2010 11:46
95 Passat AAZ leaking Diesel AmIdYfReAk Other VW Group TD(I)s 15 March 8th, 2010 00:17
Page generated in 0.08893 seconds with 12 queries
[Output: 69.76 Kb. compressed to 61.69 Kb. by saving 8.07 Kb. (11.57%)]
