Hi all, first post here, so thanks for what seems to be a great resource and community.
My Girlfriend has a 2004 Golf MkV 19TDI (if you need more info than that, let me know) that has a few issues. She's looking to get a new car and trying to find any excuse to do so, but we really can't afford it and wouldn't want to at least try to sort the issues before committing.
I've purchased a cheap VAG-COM/VCDS USB/ODB2 scanner which should be here in a few days and have sourced a copy of the RossTech VCDS to try and work out a few issues myself.
I'm trying to do my due diligence and read up on the wiki/watching videos etc., but are there any major things I should be aware of with regard to using the software/reader that might endanger the car?
Ideally I'm just looking to diagnose faults so I can have a try at fixing it myself. Hopefully its just a few relays/fuses etc.
A few of the faults are as below. Maybe someone with some experience might be able to point me to something obvious as they may be connected and give me a heads up.
Fans/blowers not working on any setting - The A/C seems to work still as we get some cold air through when we get above 50-60mph, which I presume is being forced through by the velocity.
Front wiper jets not working, when the previously had been. The jets were replaced <1 year ago and were in good working order. I can't hear a pump going and the washer fluid is freshly topped up. The wipers appear to work fine otherwise
Rear wiper not working. Again, this seems to have coincided with the previous problems occurring. The rear washer jet doesn't work either, but that has been the case for a while and I think it needs replacing.
If anyone has any advice before I get started, it would be much appreciated.
Thanks.
Thanks.
