k3ys3r_soz3
10mm ratcheting wrench to and an 8mm triple square bit and a very steady hand. Highly recommend always using white rags under your immediate work areas to prevent bits and bolts from falling into the abyss and ruining your entire day. Had to REMOVE the newly installed thermostat because one of the tstat bolts fell into the netherworld just under it - worst feeling in the world when I was so close to finishing the job and probably why my hard pipe o-ring failed on me from having to remove and install the tstat repeatedly.
