jnmarshall
My new jsw came with the kessey or whatever it's called. But I'm not sure if its working correctly or I'm using correctly. In our kia you press and release the button with you foot on the brake and it starts the car. If you leave your foot off the brake you press and release the button once and it turns on the accessories, press and release again it puts the car in the on/run and press and release it turns it all off.
On our new jsw you put your foot on the brake and it turns the car on like the on/run. Then you keep your foot on the brake and you have to press AND HOLD the button till the engine starts. Is this normal? Due to my habit with our other car I usually release the button and the engine doesn't completely turn over. I'm sure in the long run it isn't good that I have to crank it 2 or three times to start either.
