cruisertoy
For several weeks my 2000 jetta with 210k miles on it has been pulsing or surging at idle. It doesn't happen all the time but when it does it is very rythmic going from about 700rpm up to 1000 rpm. The glow plug light started flashing maybe a week and a half ago and some info here said to check my brake lights for a bad bulb, which I found one blown out. I thought I read that the glow plug ligth blinking could also be could be code for the injector pump having issues, but now i can't find that reference. I figured that since I had a brake light out that that may be the cause of the light flashing.
I changed the fuel filter saturday and the surging didn't come back until today on the way home from work at a stop light. A few miles later I heard a distinct pop from the engine compartment and lost most engine power. It still idled just fine but I quickly pulled into a gas station and popped the hood. After looking things over with the engine idling perfectly I thought maybe i had hit something in the road that caused the noise so I pulled out of the parking lot. While idling out of the parking lot i did not notice any issues. Reving the motor seemed fine. As soon as I gave it a little gas while in gear it ws obvious there was no power. It also seemed to buck and surge until I pulled into the next lot. I cannot hear the turbo, but i have always struggled to hear it on this jetta. It does not feel like the "no power" when the MAF goes out. This was get out and push it lack of power.
So I will pursue getting someone to check it out with a VAG, but any ideas of what could cause this? Blown turbo? Blown Injector pump? I had the timing belt take out the head two years ago and KarmaTDI fixed it up for me with a new head and all new timing belt stuff. I could not hear any out of the ordinary noise in the engine compartment while idling or reving it. Give me your thoughts.
