Old October 9th, 2014, 15:28   #17176
dlai
dlai's Avatar
Fuel Economy: Up There
Installed a set of GLI seats into my Golf. Pretty easy, connectors matched. Found out the rear seatback with the seat belt strap was bent. When the seatback is in the car, the middle of the seatback is four inches forward. I'm guessing the donor car was in a rear end accident and the seatback is bent because of that. Looking on Ebay and Craigslist for a replacement.
Otherwise, great seats, much better than the stock cloth OEM ones.
2002 Golf, 2005 Passat Wagon Stonehenge Gray
Chainless Since 4/22/09
dlai is offline   Reply With Quote
Old October 9th, 2014, 20:09   #17177
gary2smart
Fuel Economy: 50 MPG with 10% local driving
Removed Muffler and added a very long resonator. Nice sound at low RPM no drone at high RPM its music to my ear for now.
gary2smart is offline   Reply With Quote
Old October 9th, 2014, 23:50   #17178
Shawnz
Fuel Economy: 45 MPG
Finally fixed my 'exhaust leak noise under load' by replacing the exhaust gaskets. MUCH better! It sounded almost exactly like it does when an injector leaks but it was not leaving the tell-tale soot around the injectors.
It looked like I had one of the exhaust gasket on up side down when I installed the 17/22 a couple years and 30k miles ago and it finally let me know. How I missed that the first time around I'll never know.
2006 Mercury Montego Premier (FWD, 6 Sp auto)
2002 VW Jetta GLS TDI - 5sp swap, VNT 17/22, Bosio PP764, SBC Stg2 Daily SMF Clutch, Malone Stg 5, DG RacePipe, EGT / Boost Gauge, Evo Atlas skid, Curt hitch
Shawnz is offline   Reply With Quote
Old October 11th, 2014, 14:17   #17179
solid19snake
solid19snake's Avatar
Sold it. No more highway miles with the new commute so I sold the 2012 Jetta and got a 2015 GTI. I'll still come by to read the stories when filling up at a "gasoline" station and such though. Now I have to remember to not pull up to the diesel/combo pump for you guys!
2012 VW Jetta TDI (6MT) - DG Panzer Plate
solid19snake is offline   Reply With Quote
Old October 11th, 2014, 14:48   #17180
gary2smart
Installed Street Racer Coilovers two finger spaces above tires. Will allow it to settle ans allign next weekend.
Old October 12th, 2014, 06:45   #17181
JASONP
JASONP's Avatar
Fuel Economy: 4.5l/100
Try not to put diesel in your gasser
Sent from my SM-G900W8 using Tapatalk
2016 Jeep Wrangler, no longer do I have a diesel, repair manuals or spare parts sorry.
JASONP is offline   Reply With Quote
Old October 13th, 2014, 10:49   #17182
gary2smart
Now I need a Belly Pan any recommendations?
Old October 13th, 2014, 11:09   #17183
romad
romad's Avatar
Panzer from DieselGeek
http://www.dieselgeek.com/MK6_Jetta_...ate_s/1844.htm
http://www.dieselgeek.com/MK6_Jetta_...ate_s/1845.htm
The fleet:
romad is offline   Reply With Quote
Old October 13th, 2014, 15:05   #17184
Powder Hound
Powder Hound's Avatar
Refurbished the wiper linkage on the 4-dr last Saturday. One of the pivots was really hard to turn - that wiper motor must put out some serious torque.
Disassembled and re-greased after a clean up of the corrosion. I will find out in a couple of months if the grease is too thick for sub-zero temperatures.
Old October 14th, 2014, 19:56   #17185
Nuje
Fuel Economy: 1250km/tank
In the past few (ok - LOTS of) days:
Pulled the head after diagnosing damaged lifters
Got replacement head from Franko6 that had sand in it, plus dinged up camshaft (more on that later), so then waited on an exchange for that.
Re-installed the head.
Pulled out the 5sp.
In went the 6sp. from Frans (more on that later, too)
Pressed new TT bushings into the LCAs
Then the GT1749VC from Xman (guess what - that didn't exactly go without a hitch either; let's just say my vendor experiences on this project haven't exactly been stellar)
(Now, just waiting on Malone tune....oh, pretty please...)
And then just tonight, diagnosed the driver airbag light that came on after I'd installed the FIS/MFA wiper stalk (bent a pin on the clock spring connector when putting everything back together).
Just took it for a spin around the block...nothing fell off or exploded, so I'm feeling pretty good about it (for now at least).
Now it's just the niggly stuff: Euro wipers; wiring up the multifunction steering wheel controls to control aftermarket head unit (speaking of which, anyone heard anything on when Pioneer is releasing its CarPlay firmware update???); getting the FIS cluster installed/IMMO matched; and probably 11 other things I'm forgetting.
Nuje is offline   Reply With Quote
Old October 14th, 2014, 20:21   #17186
Caddy 16v
Caddy 16v's Avatar
Nice one, any chance we could meet up some time, currently up island for work till next week, would love to check out the butt dyno on that turbo!?
2000 Jetta, mufflerectomy, Evolution Atlas skid plate, OEM xenon reps retrofitted, Hella Micro DE, HFLOX Warp 3 nozzles, 3 bar map, Malone Stage 5 Custom, Euro 17/22, DC Stage 4 clutch, STAGG suspension, Curt hitch, Auber EGT and NSP boost gauge, Hella Sharptones, Rally Armor mud flaps, 1.8T pancake pipe, upgraded SMIC, VAG-COM, all offroaded out
2000 Golf, JSP Armadillo skid plate, limo tint (Sold)
Caddy 16v is offline   Reply With Quote
Old October 14th, 2014, 21:01   #17187
forcedfedbug
Pioneer has released the firmware for carplay already. it was released the beginning of the month. the forums for that is avic411.com
Ron
forcedfedbug is offline   Reply With Quote
Old October 14th, 2014, 23:32   #17188
Nuje
Always game for a meet up with a fellow TDI geek. ; unfortunately, I'm away so often over the next three weeks, that I honestly just don't have the time. I'll be in Victoria mid-November if you want to meet up there.
Old October 14th, 2014, 23:34   #17189
Nuje
You know - as I was typing that, I thought: Maybe I should do a quick search to see if the update was released. But then I got distracted by [who the hell knows what - internet has killed my attention span] and neglected to do so.
Downloading the update now....
Old October 15th, 2014, 07:26   #17190
forcedfedbug
Default squirrel
Originally Posted by Nuje View Post
You know - as I was typing that, But then I got distracted by [who the hell knows what - internet has killed my attention span]
squirrel
Ron
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Page generated in 0.33749 seconds with 10 queries
[Output: 133.18 Kb. compressed to 111.59 Kb. by saving 21.59 Kb. (16.21%)]
