Old January 24th, 2019, 02:49   #1
biskazz
TDI(s): A4 B6 Avant
Default Turbo graph - how does it seem to you?
Hi guys,
I decided to make a turbo graph of my stock 1.9 AVF and there are some fluctuations in the pressure it's putting out. I don't know if and how normal it is except for the initial spike so that's why I'm asking here.
Here's the graph.
It's been recently de-catted because I plan on remapping it soon but first let's sort out if the turbo is ok. This particular graph is 4th gear from 1800rpm to almost redline.
Thanks for your replies in advance!
biskazz is offline   Reply With Quote
Old January 24th, 2019, 20:14   #2
joetdi
If the car runs fine and you are not setting under boost faults I would not worry.
joetdi is offline   Reply With Quote
Old January 25th, 2019, 02:38   #3
biskazz
TDI(s): A4 B6 Avant
Yep, it's running fine. I read somewhere that fluctuations like these may be because of a boost leak.
Old January 25th, 2019, 12:30   #4
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
If you go to Malone Tuning site you can upload your .csv file and harvest a prettier presentation of your data. Cause I'm not sure exactly what the parameters are, and can't interpret anyway. There are a few folks who can.
There's also this Windows application if you want to do it your own self-
Dropbox link - LogPlottingApplication.zip
Old January 25th, 2019, 13:59   #5
Curious Chris
Fuel Economy: 47/42/38
The only strange part to me is the rise at the end. The decreasing fluctuations around the target are typical. I would do a longer run logging the data as you can make a nice graph in excel. I did a 10 second run at full throttle and eventually the boost should settle in at the specified MAP with just a little A to D ripple.
Curious Chris is offline   Reply With Quote
Old January 26th, 2019, 15:25   #6
biskazz
TDI(s): A4 B6 Avant
I'll try to log a couple of more pulls and see what happens. Thanks for the input guys!
Another graph, because who doesn't like a good graph. Diesel vs Gas SkeeterMark TDI Fuel Economy 30 November 12th, 2013 18:01
Sticky Turbo graph? sdeck TDI 101 4 April 17th, 2008 12:09
Turbo overboost - check this graph! DaveyUK TDI 101 22 August 1st, 2006 03:25
VAG-COM Graph: Dead Turbo? vaughn OBD Scanners 2 August 29th, 2005 19:09
Vag-Com Graph: Dead Turbo? vaughn TDI 101 4 August 29th, 2005 18:16
Page generated in 0.12285 seconds with 11 queries
[Output: 71.37 Kb. compressed to 62.53 Kb. by saving 8.84 Kb. (12.39%)]
