Old January 23rd, 2019, 20:00   #1
DavidAlltheTime
Default Window Regulator Clips
2002 Golf Tdi.
Failed regulator clips and cables in the front drivers side window. We bought a 3rd party repair kit so we also changed the cog that the motor turns to move the cables to lift the clips that hold the window as it moves up and down. It's quite the contraption.
We can't seem to twist the clips to bring the cables to the correct tension. It honestly seems impossible that there could ever be enough slack to turn the clips the way they're supposed to sit in the rails, like the fella in this video does.
Has anyone reading this made this repair work? Any tips? I'm worried the rubber covering for the cable that came with the 3rd party kit is too long, and by trimming it, I could free up more cable, but I don't want to mess it up. It does seem longer than the original tubing.
Thanks for thinking about my window!
DavidAlltheTime is offline   Reply With Quote
A-4 Window regulator clips Herm TDI TDI 101 5 April 25th, 2014 16:21
Window Regulator Clips? cgi2099 TDI 101 4 February 18th, 2011 12:20
Window Regulator Clips? kerouacknew TDI 101 13 April 24th, 2007 15:49
Window regulator clips Hamsterdiesel VW MKIV-A4 TDIs (VE and PD) 13 March 19th, 2003 03:50
What is with the window regulator clips? Betzel VW MKIV-A4 TDIs (VE and PD) 1 September 29th, 2002 07:14
Page generated in 0.10627 seconds with 11 queries
[Output: 46.92 Kb. compressed to 44.24 Kb. by saving 2.68 Kb. (5.71%)]
