Old January 23rd, 2019, 13:30   #1
TNTKNC
TNTKNC's Avatar
TDI(s): 2003 Jetta
Fuel Economy: 40-44
Default Low voltage to headlight
I've been trying to find this through search but not having any luck. I'm not good at wiring don't really like it much. However I have a 2004 Golf and the passenger side bright headlight isn't working. With a bit of checking I found that I'm only getting 7 volts to the headlight from the harness. All other lights are working. I looked as best I could in the Bentley but I have no skill with these diagrams. I suspect that both lights somehow feed together but was wondering if someone can point me in the right direction as to where a problem might exist. It does have Hella Glass front fixtures and HID low beams installed, however that all works its just the Bright light. Any help would be appreciated.
I now have Vag-com and TB tools. I live on the North side of Atlanta. PM me if you need some work done.
2003 Jetta GLS TDI. Ventectomy, pp520's, RC4+, 11mm pump,17/22 Hybrid, FMIC, VR6 G60, .681 Fifth gear.
TNTKNC is offline   Reply With Quote
Old January 23rd, 2019, 14:10   #2
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
What did the other lights measure? Since I don't know if 7 V isn't correct, if that's way low it's more than likely a wire or connector.
Old January 23rd, 2019, 17:19   #3
TNTKNC
TNTKNC's Avatar
TDI(s): 2003 Jetta
Fuel Economy: 40-44
The other lights were battery voltage. So 11. 7 to 12
Old January 23rd, 2019, 20:57   #4
mr.loops
TDI(s): 2002 jetta
First off Iím assuming you checked the bulb
I would plug the bulb back into the socket and with the light switch ON perform a voltage drop test on that circuit
To keep the math easy and less confusing your going to perform two tests on the circuit.
1) With the voltmeter set at 20v take one lead of your dvom and back probe the negative wire on the light socket and the other lead connect it to the negative battery post. Record your reading
2) perform the same test, as above, but do the positive side of the circuit. Record your reading
Note: in order for the above test to be valid you MUST have the bulb(load)plugged in and the lights ON. In both tests you donít wonít to see a voltage reading greater than 0.5 V. If you do, then you have an issue with the circuit ( corrosion, bad connection etc)
mr.loops is offline   Reply With Quote
Old January 24th, 2019, 14:13   #5
TNTKNC
TNTKNC's Avatar
TDI(s): 2003 Jetta
Fuel Economy: 40-44
I believe I understand what your saying. I will see what I can find out. Yes bulb is fine.
Old January 24th, 2019, 17:37   #6
Mongler98
Use a volt meter or a prob and test the voltage at the fuse for both headlights. If you have 12 at both, your issue probably is within the relay for the high low beam. Find the relay and test it.
i would put my money on a bad relay. they do after all just have contacts in them and with age, they start to get pitted from arcing.
Old January 24th, 2019, 19:59   #7
joetdi
[QUOTE=mr.loops;
This is exactly how you do this, however if the headlight bulb is a high and low beam in one you can skip the voltage drop test on the ground side as the low beam works and uses the same ground as the high side.
The wire you want to check is the power wire for the high beam the one he says he has 7 volts on, from the bulb to the battery. Not doubt there will be a drop that is to high. From there you move the probe closer to the battery from the bulb until voltage is low, less than .5 volt. In most cases you like to see .2 to .3 volt. In this circuit higher would likely not be noticed.
joetdi is offline   Reply With Quote
Old January 27th, 2019, 12:12   #8
TNTKNC
TNTKNC's Avatar
TDI(s): 2003 Jetta
Fuel Economy: 40-44
Hoping to get back to this this week. I'm working and haven't had time. I will post results. Thanks for the help so far.
//// Low voltage issues ?? //// Andyinchville1 TDI 101 3 July 13th, 2017 21:47
stock headlight voltage dak503 VW Passat Family (NMS and B7) TDIs (2012+) 2 February 4th, 2017 10:12
Headlight Voltage is 10.5 volts... ? bob57434 VW MKIV-A4 TDIs (VE and PD) 18 December 22nd, 2015 14:36
'05.5 BRM. low-beam on one side won't work. low voltage Jesse_Boyer VW MKV-A5 Golf/Jettas 2 June 23rd, 2013 08:50
Low voltage??? 2Dambad TDI 101 3 January 4th, 2007 09:05
Page generated in 0.14005 seconds with 11 queries
[Output: 86.24 Kb. compressed to 74.38 Kb. by saving 11.86 Kb. (13.76%)]
