Old January 23rd, 2019, 12:06   #1
ratkc135
ratkc135's Avatar
Default Starter & Cables
My starter has struggled some so far this winter...taking 7-10 seconds to start when it was around 5-8 degrees. Battery checks OK...not great...but descent.
So I don't get stranded (I'm an airline pilot that leaves this car in employee parking lot) I think I may just replace battery, starter and the cables (ground, battery to ALT, etc). Wanted to see if anyone has had good luck with this kit I found to replace the wiring:
http://innovativewiring.com/?page_id=5332
If you don't like this kit...any other kits out there? I could always buy wire..and make them...but a kit saves me some time. If you all like this kit...any idea what length cable I need? It has I think at least 3 options.
As well as this starter:
https://smile.amazon.com/dp/B00T689U...v_ov_lig_dp_it
Good reviews on amazon and for $68. Then what I'll do is rebuild the OE starter and have that as a backup...then I can always have a rebuilt one on hand.
Is it necessary to do the wiring? Probably not...I read that corrosion can cause some starting issues as well as battery and/or starter....but if I'm going to remove battery to get to starter...why not get some new cables in there..then finish off with a new battery. That way my starter/battery/cables are good to go for another 17+ years...lol.
Rat
2002 Jetta TDI GLS - White
2013 Passat TDI - SOLD Back to VW
ratkc135 is offline   Reply With Quote
Old January 23rd, 2019, 12:55   #2
drucifer
Your parts list is as follows
Harness $155
Battery $120 and up
POS amazon alternator $68
Maybe a cheap starter 50 to 75
Now your in it 400 in parts. How about doing some testing and see what it needs. Your said you'd rebuild parts to have on the shelf. Why not just rebuild them and stick them back in.
On the alternator here's a reman bosch for $179.
https://www.metalmanparts.com/produc...&categoryId=38
I understand you have the $$ to shoot the parts cannon at it but what would you learn? It might be satisfying to diagnose and repair the first time. Buying cheap components your going to get good at changing them.
Test first repair or replace second.
drucifer is offline   Reply With Quote
Old January 23rd, 2019, 13:02   #3
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Not that I'm against throwing parts at it, you need reliability, but all those components can be tested. Diesels like strong batteries, some have had the cable to the alternator corrode inside the sheath as well as bad connects. Get a real new or certified rebuilt Bosch alternator if you need one.
Old January 23rd, 2019, 18:54   #4
AndyBees
AndyBees's Avatar
The second link is to an Amazon Starter.. not an alternator!
This is the TDI Club, a place to share experiences & ideas, ask for help, etc. Welcome Newbies! Sarcastic and condescending posts shouldn't be welcome.
Old January 23rd, 2019, 19:04   #5
ratkc135
ratkc135's Avatar
That was a typo. Fixed now. I meant starter.
Rat
Old January 23rd, 2019, 19:49   #6
drucifer
So here's a starter, but it's the same idea. Test it and change it once.
https://www.metalmanparts.com/product.sc?productId=654
Old January 23rd, 2019, 20:06   #7
Satsonic
Satsonic's Avatar
TDI(s): 2006 Jetta
Fuel Economy: 38
Like the others have said. I recommend a new battery AGM technology. If your cables arenít very corroded Iíd leave those alone. If anything they typically just need a cleaning at ends, and a simple ohm meter can tell you whether there is too much resistance. But like the others have said itís likely just your battery. Diesel vehicles really like good strong batteries.
Satsonic is offline   Reply With Quote
Old January 23rd, 2019, 21:28   #8
STDOUBT
STDOUBT's Avatar
AS others have said, if your car did not come from the factory with an AGM battery, don't buy one. Yes, I'm just repeating what old-timers here have said, but these guys are engineers and highly experienced daily mechanics.
As for a starter motor, a reman BOSCH is your best bet.
If I was having the symptoms ratkc135 is having, I'd just slap in a new starter and see if the problem went away. I'd baby along the battery and while I would inspect the cables, I wouldn't replace until they show signs of corrosion. Corrosion doesn't start deep inside the cable. You'll see it at the ends well before it starts interfering with operation.
ratkc135,
Get a BOSCH reman, and take your old one someplace good that rebuilds them all day. Bam. You're set.
EDIT: and if you're at all worried about your battery, get a nice 94R sized replacement. Dealerships should have good prices.
2003 Jetta TDI 1.9L 5-speed
Malone Dynamic EGR ~ cooler delete ~ Euro pipe ~ ventectomy
Search Tip: search this site best by using Bing: tdiclub topic
STDOUBT is offline   Reply With Quote
Old January 23rd, 2019, 22:58   #9
ratkc135
ratkc135's Avatar
Harness $155
Battery $120 and up
My thought process was I remove battery, battery box and most of the wires to get to starter...I could swap battery and cables at same time. I always have bad luck so I figure Murphyís law strikes and a few months after starter...battery dies...few months later I have wiring issues. Lol. My issue with taking out starter and rebuilding that one; its my daily driver and I suppose I could do it all on a weekend but with it being in the teens I wanted to be able to swap it out and be done and not chance having it disabled for work come Monday. Or risk getting stranded after it sits in airport employee parking when I canít start it.
Seems to me for a core charge it would be worth just having a second starter..then I could rebuild that one taking my time. Iíve watched some video on how to rebuild and it doesnít seem too tough...or as was mentioned earlier I take it somewhere that does it everyday.
As mentioned above I can just inspect the cables and use contact cleaner and sandpaper to clean those up. The car spent 90% of its life in AZ so I would doubt the cables are an issue. So that saves me $155+. But I donít know what else it would be besides battery or starter that is causing it to take 10 seconds to start when itís 8-10 degrees. Iíve noticed it getting worse in the 2 years Iíve had it. Oreillys said battery wasnít real strong (based on CCAs) but itís ďfineĒ. Stray led me to believe itís a starter issue.
Is there a way to test the starter? I read you can read starter rpm in VCDS (which I have). But Iíd have to do that when itís cold...and even then it could be the battery causing that too no? Iím also going to use the trick I found that I can add a few seconds to glowplug time in VCDS. No codes so I think all my GPs are working.
Rat
Old January 23rd, 2019, 23:21   #10
ratkc135
ratkc135's Avatar
So in this case I would pay $92.40 more to keep my old one. Well less than that as Iíd have to pay to ship it.
$268.87 total
Iíd have to shop around to see if I could find better.
I read VW also used/uses valeo starters? Bosch is better and the way to go?
Rat
Old January 24th, 2019, 00:30   #11
drucifer
I understand about needing your car. Check out this thread for rebuilding.
http://forums.tdiclub.com/showthread.php?t=465001
There's nothing to say you can't buy an auto parts store starter or a junk yard starter and the rebuild kit. Test the new to you starter at the store. Yes even if it has a warranty. Purchase a rebuild kit. Remove starter and clean all your power and grounds. If the rebuild is a fail stick the jy starter in there or the parts store starter as you prefer. Jy starters 20 to 35. Even at the full serve jy. Or just pony up the cash for the factory rebuild and send them a jy one. If you wind up not using the parts store starter just return it.
Old January 24th, 2019, 07:16   #12
AndyBees
AndyBees's Avatar
Always pull your park brake up before turning the ignition ON....... that procedure turns off the Day-time Running lights. Wait until the interior light goes off too. I think it stays on for a few seconds even if the key is inserted and turned on.
Old January 24th, 2019, 08:02   #13
ratkc135
ratkc135's Avatar
Oh yes always! I wait until the dinging is done which is after the GP/idiot light extinguishes. Iím gonna add a couple seconds via VCDS to help with a bit more GP time below 10F.
Rat
Old January 24th, 2019, 08:05   #14
Mongler98
Replace battery if need be. How are you testing it?
Old January 24th, 2019, 08:14   #15
ratkc135
ratkc135's Avatar
OíReillyís load test. Itís only when cold it struggles so it has to be battery and/or starter I assume...
Rat
CCM cables black&red? frosz VW B5 Passat TDIs 2 June 13th, 2016 13:19
where to run Amp Cables mattds VW MKV-A5 Golf/Jettas 2 July 19th, 2011 17:44
Where to Mount an Amp? Run Cables? Hank101 VW MKV-A5 Golf/Jettas 9 July 29th, 2010 12:53
WTB // Shifter & Cables for 99.5 cod Private TDI Items for Sale/Wanted 8 January 3rd, 2010 16:19
Wanted: VAG-COM & Cables Herm TDI Private TDI Items for Sale/Wanted 3 February 17th, 2002 12:13
Page generated in 0.21392 seconds with 11 queries
[Output: 135.18 Kb. compressed to 113.39 Kb. by saving 21.79 Kb. (16.12%)]
