Old January 20th, 2019, 17:04   #16
bizzle
bizzle's Avatar
You can get that info from the ECU if that's your reasoning for this thread. Cheapest solution would be to get a cheap bluetooth OBD2 reader and the Torque app on android. I don't use it, I don't know anything about it, so maybe it will maybe it won't work for your application but that's what I've seen on the boards. There is also a hardware module called POLAR FIS+ that I believe does the same thing but outputs it to your MFD.
bizzle is offline   Reply With Quote
Old January 20th, 2019, 17:14   #17
Mongler98
Scan gauge II will do that trick. I love mine but he MK3 does not have that ability to show EGT's as its not monitored. If you car has this, scangaugeII will show it and you can program it to show whatever the car has for sensors. But according to your sig, your MK4 does NOT have an EGT monitor. there is not any way for your ECU to get that data, and to be able to monitor it, and log it, (as far as i know) the only gauge that has any ability to do so is an AUBER gauge with the alarm connected to a raspberry Pi with some trick programming though some logic board to send the 5v signal from the gauge to the PI as an input. These AUBER gauges are designed for food prepossessing and other types of prepossessing machines, i don't know everything about Auber but it would seem logical that they would have some standalone logging for there gauges.
Old January 21st, 2019, 05:43   #18
Curious Chris
Fuel Economy: 47/42/38
Yes the ECM will tell you boost but if you want EGT you need to buy what I have which is a dual pod with EGT gauge. No it was not cheap but I can compete with any scan guage price and then buy the no drill EGT from idpart. This setup is on the shelf in my garage and I am moving towards single pod with boost. .
Curious Chris is offline   Reply With Quote
Old January 21st, 2019, 08:18   #19
1854sailor
Resident Curmudgeon
1854sailor's Avatar
The OP has an '04 with the BEW PD engine so, IIRC, EGT should be able to be read from the ECU on a ScanGauge or one of the OBD II apps.
-George Bernard Shaw
Old January 21st, 2019, 09:13   #20
AndyBees
AndyBees's Avatar
1854sailer, that's interesting to know. I've done maintenance on only one BEW, including VCDS scan. I never saw anything about EGTs, but I wasn't looking for it either.
Thanks for sharing...
This is the TDI Club, a place to share experiences & ideas, ask for help, etc. Welcome Newbies! Sarcastic and condescending posts shouldn't be welcome.
Old January 21st, 2019, 09:18   #21
Mike_04GolfTDI
Mike_04GolfTDI's Avatar
The only sensors in the exhaust on the BEW engine are an oxygen sensor before the catalytic converter.
I've never seen EGT with VCDS on my car. I don't think that's available. Would be happy if someone says I'm wrong and it does.
2004 Golf GLS TDI 5-spd, DC Stage 1 Clutch, Evolution Atlas Skid Plate, Malone Stage 4 Tune, GT1749VB Turbo, 3 bar MAP
Mike_04GolfTDI is offline   Reply With Quote
Old January 21st, 2019, 10:22   #22
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Hey, Mike, I'm only saying this because the PD BHW in our old B5.5 Passat had an EGT probe. Are the PD BEW and BRM's different? Edit: I meant other than being 1.9L instead of 2.0L of course.
Egt and boost gauges Speardog VW MKIV-A4 TDIs (VE and PD) 3 July 12th, 2015 14:20
Boost and EGT Gauges extreme202 VW MKVI-A6 Jetta Sedan (~ 2011+) 12 April 10th, 2014 07:14
Boost and EGT gauges robbieyukon VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 3 February 3rd, 2011 12:18
Good source for boost and EGT gauges? 02PSDV8 TDI 101 4 April 30th, 2010 08:27
What boost/EGT gauges do you have and use? Fortuna Wolf General Automotive 23 June 13th, 2006 13:41
Page generated in 0.18054 seconds with 11 queries
[Output: 84.77 Kb. compressed to 73.57 Kb. by saving 11.20 Kb. (13.21%)]
