Old January 19th, 2019, 10:17   #1
xadzer
Default 1.9 TDI AXR turbo whine, normal?
So I have noticed on my car when the engine is cold after starting it overnight the turbo seems louder and has some of the dreaded whine/siren noise however after the engine warms up the noise goes away, is this normal I have linked a video so you guys can hear it, turbo is new has like 15k KM on it car has about 97k KM car is a MK4 Jetta
https://youtu.be/FfKubuA3eaU
xadzer is offline   Reply With Quote
Old January 19th, 2019, 10:20   #2
flee
Fuel Economy: 40-ish
Why a new turbo on such a low Km car? What make/model of turbo and was it NIB?
2002 Jetta GLS TDI wagon
flee is offline   Reply With Quote
Old January 19th, 2019, 10:23   #3
xadzer
Car was ditched for 6 months without being started at all, then it was started without checking anything and turbo went bad as well as the injectors which were also replaced, its a KP39, replaced with a brand new OEM unit by BorgWarner.
Might be too paranoid about the sound as I have seen other tdis make it too, not sure though.
Old January 19th, 2019, 11:17   #4
flee
A car sitting unused for 6 months should not affect the turbo.
Whatever killed it could be doing the same to the new turbo. Low oil pressure? FOD?
Pull off the outlet hose on the turbo and use a mirror to see if there is a mark where
the compressor wheel has made contact. *Sorry, this should have said inlet hose.*
Last edited by flee; January 19th, 2019 at 19:37. Reason: Wrong hose mentioned in original post.
Old January 19th, 2019, 11:27   #5
xadzer
Car is due for an oil change and I just checked the oil and the level is a bit below the cross check pattern on the dipstick so I will be doing an oil change today, im not entirely sure there is something wrong with the turbo as the car still pulls hard and doesnt smoke at all, if there was something wrong with it wouldnt the noise be present at all times? It goes away after driving for a bit once car gets warm.
Old January 19th, 2019, 11:37   #6
flee
The sound on your clip isn't as loud as mine was went it started squealing.
I continued driving it for at least 6 months without losing any oil and then replaced.
Old January 19th, 2019, 12:10   #7
xadzer
I have researched around and see people with louder noises that claim turbo is bad, however other people claim its normal, sound isnt loud at all and goes away so I will assume its normal operation.
Old January 20th, 2019, 14:48   #8
xadzer
https://youtu.be/wtIqo688S30
Here is another clip, sound comes in when you let off the throttle at around 1500-2000 rpm it isnt there while accelerating, some people say its normal others say replace turbo, it has just been replaced 10k kms ago, any ideas anyone?
Not burning up any oil, also in the video the sound is really loud because car is parked close to 2 concrete walls so they reflect sound alot.
Old January 20th, 2019, 15:00   #9
fouillard13
pretty sure thats just a bird chirping and not coming from your turbo dude....
fouillard13 is offline   Reply With Quote
Old January 20th, 2019, 15:20   #10
xadzer
Lol yeah I hear the bird but listen to the engine, especially when revving inside the car.
Old January 20th, 2019, 15:59   #11
xadzer
https://youtu.be/GMHe8JTRWEM for example, here is a guy with pretty much the same sound as me and he claims there was nothing wrong with the turbo for close to 100k kms, am I in the clear?
Old January 20th, 2019, 16:14   #12
fouillard13
I personally don’t hear anything out of the ordinary. Keep in mind I’m a total noob though. I’m sure a more experienced member will chime in soon
I’ll see if my car makes the same sound next time I’m in it
Old January 20th, 2019, 19:21   #13
xadzer
Ugh such an annoying issue if that, seems its 50/50 on the turbo being fine or how its about to blow up, which wouldnt make sense seeing it has 10k kms on it, not sure what to think.
Old January 20th, 2019, 19:38   #14
Carlos_TJ
OP
How is the axial and lateral play of the impeller?
i would visually inspect impeller for signs of it touching the housing.
Carlos_TJ is offline   Reply With Quote
Old January 20th, 2019, 19:42   #15
xadzer
Originally Posted by Carlos_TJ View Post
OP
Honestly besides basic car maintenance, im not mechanically savvy enough to know how to check the turbo itself.
Can I fit a AXR turbo on BEW jettabeast TDI Power Enhancements 1 November 14th, 2018 17:16
Whine from transmission - normal? moroza VW MKIII-A3/B4 TDIs 6 April 18th, 2017 16:17
Golf IV AXR 2003 with GTB1756VK turbo alex95kitto VW MKIV-A4 TDIs (VE and PD) 0 March 7th, 2017 00:53
VW Golf V 1.9 TDI 90 HP turbo whine/whistle, normal or pathological? dalex2093 VW MKV-A5 Golf/Jettas 1 July 17th, 2016 05:54
Slight Drivetrain Whine, Is This Normal? PDJetta VW MKIV-A4 TDIs (VE and PD) 3 August 13th, 2007 06:26
Page generated in 0.09475 seconds with 11 queries
[Output: 120.51 Kb. compressed to 99.46 Kb. by saving 21.05 Kb. (17.47%)]
