Old January 16th, 2019, 09:50   #1
ricefarm
Default Vag com
1st off if this question has been answered already my apologies, I can not find the answer searching.
2nd if this is in the spot please move to where it needs to be.
I am wondering about vag-com and what it can and can not tell you. Can it tell if your veritable cam sensor is working, does it graph you cranking till start values? Just what exactly can this program tell you. Is there a book to help with what codes to enter so you get the readout needed?
ricefarm is offline   Reply With Quote
Old January 16th, 2019, 10:06   #2
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
A better place for this would be here- OBD
Vagcom (older) or VCDS is the best diagnostic tool for the money. They do sell a "book".
Can't say I've seen a definitive list, but look at RossTech.com for more info. Perhaps even contact them with your questions, they're very helpful.
Most of us have learned to use it in small bites. Basically it reads most things managed by the ECU, it's not comprehensive and no replacement for mechanical knowledge. You do need a device for certain functions.
Old January 16th, 2019, 15:41   #3
ricefarm
BobnOH Thanks for the information, I'll take a look at Ross tech and see what I can find.
Southeast Virginia VAG-Tacho or VAG Commander? arne487 Eastern USA 0 December 2nd, 2011 14:13
VAG-Com\VAG 1551\VAG Tool CraCol TDI Power Enhancements 5 July 17th, 2011 22:46
'06 Jetta VAG Codes (VAG-COM Newbie) Bugzilla OBD Scanners 7 May 4th, 2006 08:33
FS VAG-COM SERIAL, BENTLEY CD, VAG COM, VAGCOM Aero-TDI Private TDI Items for Sale/Wanted 6 August 26th, 2003 19:05
Audi 2+2 adapter for VAG-COM, VAG 1551 or similar christi Private TDI Items for Sale/Wanted 2 November 1st, 2002 09:02
Page generated in 0.18389 seconds with 12 queries
[Output: 57.00 Kb. compressed to 51.81 Kb. by saving 5.20 Kb. (9.12%)]
