Old January 15th, 2019, 21:48   #1
bizzle
bizzle's Avatar
Default Intermittent rolling gravel sound from suspension or drivetrain
2015 Golf w/ DSG experiencing periodic gravel-ish sound.
Buddy was driving up a mountain about 6 months ago and called me to tell me he thought something was wrong with his wheel. He got off the freeway and checked the tire pressure, made sure nothing was rubbing, but that was the extent of his capabilities and he kept driving another hour. The sound went away on his own during that time and it sounds like he never followed it up with anyone.
I'm backing his car out of his driveway this evening and for a brief moment I hear some weird sound. I check if I hit a palm frond, but it sounded more metallic than that. I go inside and ask him if he's heard it before or what has been going on with his car. He says nothing has happened. I hop back in and drive it all over town for an hour and eventually this sound starts back up:
https://youtu.be/GS_jQUFK6Jk
I wasn't doing anything differently than I was doing earlier other than laying into the pedal a bit to listen how everything was working like I thought it should, but no pattern that I could figure that would make the sound happen again and I couldn't do anything to force it after it went away. What did seem to make it go away was putting it in reverse for a second and then going forward, but I didn't hear or feel anything in park or reverse. DSG is shifting smoothly and car is accelerating and braking normally.
After I texted the video to him he said that sounded like the sound he heard about 6 months ago. He though it was coming from the front passenger wheel, whereas it seemed to be coming straight up through the center console...but that was just from sitting in the driver's seat so sound could be traveling anywhere.
Any ideas of where to start looking? I completely forgot to check for codes, but I do have a VCDS.
bizzle is online now   Reply With Quote
Old January 16th, 2019, 04:01   #2
bizzle
bizzle's Avatar
No codes.
Does anyone agree the sound is pointing to the DMF?
But does a DMF starting to go out rattle for like a minute or two and then not make any sound for months?
I have no idea the conditions he first heard it, but when I heard it today it was just a quick *crunch* sound and I hopped out right away to see what had happened. I saw nothing and then drove through town trying to induce the symptom. When it finally happened again, I shot that video. It didn't do it in neutral or park, just forward and seemed like it would have kept doing it until I finally shifted into R for one second and then back forward again (fully stopped, not a rolling R to D ) and it stopped immediately upon backing up.
Old January 16th, 2019, 04:32   #3
bmwM5power
bmwM5power's Avatar
were u not applying any throttle moving forward? does it go away when you press the accelerator?
bmwM5power is offline   Reply With Quote
Old January 16th, 2019, 04:38   #4
bizzle
bizzle's Avatar
That video is me in the parking lot in D with my foot on the brake.
I then apply throttle up to slow parking lot speed and take my foot off the throttle.
You can kinda hear the crescendo as I do that but the sound signature doesn't really change (just the tempo and possibly intensity).
I didn't get a real good sense of much else because I don't like fiddling with my phone while driving, but I turned into the nearest parking lot and was focused on getting as much of it recorded for the owner and the forum before it went away as safely as possible.
Old January 16th, 2019, 06:57   #5
Mythdoc
Mythdoc's Avatar
I’d pull the wheel and check. It costs nothing and who knows? I’ve had debris/gravel in the wheel and it makes noise that goes away at speed.
“Yeah, well, y’know, that’s just like, uh... your OPINION, man.” —The Dude
2015 Q5 TDI w/ Chipwerke tuner, 30K Miles
2015 Golf TDI SE, Lighting Package, 16K miles
2011 Touareg TDI (sold back, May 2018); 2015 Golf TDI S (totaled, Oct 2018)
Mythdoc is online now   Reply With Quote
Old January 16th, 2019, 08:34   #6
The Tortoise
My first thought was a rock was stuck in the brake shield. It happened to me and it made a hell of a noise. It took prying against the shield with a screwdriver to break it free.
The Tortoise is offline   Reply With Quote
Old January 16th, 2019, 10:14   #7
bmwM5power
bmwM5power's Avatar
I dont think this is wheel related as mentioned above. I remember having a 2012 VW Golf with DSG that has this issue from new. When I was pulling into my driveway and going slightly uphill slowly I would not touch the accelerator and it would start rattling like that, I touch the throttle and it would go away. I could also induce this on the parking lot by pretty much doing the same, let the car drive slowly on idle, no throttle, or sometimes Id touch the brake slightly and it would start to rattle. Went to the dealer 5-6 times they obviously said there was nothing wrong with it, no codes, shifts fine. One of their foremans even listened with the stethoscope and said it sounds like its coming from the differential, but they did nothing because it was performing fine other that occasional rattle. I got sick of listening to this, traded the car in with only 4000 mi on it, for the manual transmission, that was the end of the story.
Old January 16th, 2019, 11:20   #8
bizzle
bizzle's Avatar
Oh man that's not reassuring!
I'll check for foreign objects but it doesn't feel like that's it if you know what I mean.
Old January 16th, 2019, 18:33   #9
bigb
I bought one of these a few years ago to pinpoint a rattle on one of my trucks and it worked great, of course mine was not intermittent, I could make the sound by just hitting bumps. I traced it to a leaf spring.
https://www.amazon.com/STEELMAN-0660...HHGBSSETGZ3999
bigb is offline   Reply With Quote
Old January 16th, 2019, 18:34   #10
bizzle
bizzle's Avatar
I had my buddy drive around his block a few times, so he drove for about 20 minutes I guess at pretty much idle speed then whipped it up and down a desolate street at 100mph but wasn't able to reproduce the sound again.
Old January 17th, 2019, 07:35   #11
bmwM5power
bmwM5power's Avatar
try to go slightly uphill from stop at idle rpm ( 1st gear no throttle), like on the driveway
Old January 17th, 2019, 16:53   #12
bizzle
bizzle's Avatar
Tried it three times and can't reproduce it.
Trying a big screw driver now
Transmission Limp Mode On, Grinding Sound When Rolling Rome VW B5 Passat TDIs 8 February 21st, 2013 12:08
Wagon Suspension for Mixed Use(Gravel, Dirt, Pavement) CalvinM VW MKIV-A4 TDIs (VE and PD) 2 July 10th, 2011 07:30
Suspension/drivetrain experts near Chelmsford, MA? mod Eastern USA 3 August 28th, 2009 07:20
Faint "marble rolling in a tin" sound on accelerating passat130 TDI 101 9 April 21st, 2008 19:20
New bearing - same grumble sound rolling - ideas? teleskier VW MKIV-A4 TDIs (VE and PD) 11 October 22nd, 2003 08:02
Page generated in 0.19067 seconds with 11 queries
[Output: 108.98 Kb. compressed to 92.08 Kb. by saving 16.90 Kb. (15.51%)]
