Old January 14th, 2019, 23:29   #1
Fox5150
Default 2015 Golf TDI exhaust smell
I recently purchased a used 2015 Golf TDI
It started to smell like exhaust when starting.
The smell went away when driving but smelled again when stopped at a light.
My wife said she started to get a headache and my kids said they were feeling sick.
I called the dealership and they had me bring it in.
I had a 2011 Jetta TDI and I never smelled anything like this before
I literally had the car 2 days
What questions should I ask?
Can I return the car after 2 days?
thanks
Dave
Fox5150 is offline   Reply With Quote
Old January 15th, 2019, 09:40   #2
The Tortoise
If you just bought it, it might have had phase 2 of the emissions recall done. People have noticed the odd smell from either the new components or the new components not being installed correctly.
If it persists, i.e. is still happening, then bring it in to the dealer.
The Tortoise is offline   Reply With Quote
Old January 15th, 2019, 10:04   #3
jonferns
jonferns's Avatar
TDI(s): '15 Golf
If you're smelling exhaust, it is possible the dealer misaligned the turbo/DPF connection during the phase 2 fix. I just had my phase 2 done and smell nothing under the hood with the car running
'15 Golf S TDI - 80k, DSG
'12 JSW TDI - 99k, 6MT Buyback complete!
'06 Jetta TDI - 160k, DSG, Package 2, Malone Stage 1, RCD510 Retrofit
'06 Jetta TDI - 230k, DSG
jonferns is offline   Reply With Quote
Old January 16th, 2019, 04:31   #4
Matt927
Matt927's Avatar
TDI(s): several
You should not be smelling any raw diesel exhaust smell in the cabin period. If the car has had both phases of the fix and was sitting on the dealer lot before you bought it, I would start with exhaust plumbing that was removed for the fix.
Open the hood, stick your nose toward the back of the engine where the turbo is located, is the smell present with the motor running?
What has the dealer said to you?
Matt927 is offline   Reply With Quote
2015 Golf TDI exhaust size? CiDirkona TDI Power Enhancements 1 May 4th, 2017 15:34
2015 TDI Passat (EA288) with oil smell ktpett VW Passat Family (NMS and B7) TDIs (2012+) 29 January 6th, 2015 19:04
My TDI Exhaust does not Smell Like Other Diesels duwem VW MKIV-A4 TDIs (VE and PD) 9 July 6th, 2012 08:58
Golf exhaust smell w/windows open? LexDM3 VW MKIV-A4 TDIs (VE and PD) 3 July 2nd, 2003 13:01
Exhaust Smell in Golf---HACK!!! dparnell VW MKIV-A4 TDIs (VE and PD) 6 June 5th, 2001 19:51
Page generated in 0.11811 seconds with 11 queries
[Output: 62.80 Kb. compressed to 56.26 Kb. by saving 6.54 Kb. (10.41%)]
