Old January 14th, 2019, 22:33   #1
sportwagen3
Default Hard Shifts from 1st to 2nd in Cold Weather
Recently the temperature has been in the upper 20s to lower 30s. I noticed on cold starts when my car's not garaged or after work when my car's been in the parking lot for over 8 hours, shifting from 1st to 2nd gear is rough at times for my manual car. When I shift into 2nd gear, the gear doesn't engage smoothly and I feel kickback from my shift knob as 2nd gear is engaged. Once the car warms up within a couple minutes, the shifts are completely smooth.
I'm wondering if anyone else has this issue? If so, what could be the cause of the problem?
sportwagen3 is offline   Reply With Quote
Old January 15th, 2019, 04:52   #2
Z85rado
i've always thought it was gear lash. my wrangler had a very low first gear and if you tried to bang 1-2 it was forceful.. i used to pause a second to let the gears slow a bit.
I didn't take the VW yesterday when it was 9 in the morning. we have a chevy with a tremec 6060 and it was very stiff for 15 minutes or so.
Z85rado is offline   Reply With Quote
Old January 15th, 2019, 08:44   #3
vwdsmguy
Fuel Economy: 49/46/42
Default shifter lube
To make for easier shifting I pull the shifter boot up and squirt oil on the white ball at the base of the shift lever. What a difference it makes. Try it.
'02 Golf TDI, RC5, PP764's, FMIC, 2.5" T-Back, OMI, SB-3 clutch, 11mm pump, VNT17/22, 3 Bar MAP, CAT filter, 90 GPH Holley lift pump, modded D24 intake manifold, Rosten rods, Nural pistons, ported head - 15.0 @ 94 at the drags
vwdsmguy is offline   Reply With Quote
Old January 18th, 2019, 07:44   #4
ESmith813
Definitely going to try this! I'll dive in next time the cabin's warm enough for the plastic to not be so brittle.
ESmith813 is offline   Reply With Quote
Old January 27th, 2019, 21:35   #5
UmeshT
Fuel Economy: 41.xx so far
I've been dealing with the same thing with mine. My 1-2 and 2-3 shifts seem notchy until the cars and gearbox if warmed up.
2015 Golf SE TDI 6 Speed Manual White
2015 Ram 3500 Limited CTD Black
1997 Nissan 240SX SE Pearl White (x2)
1998 Toyota Supra TT 6 Speed
2019 Honda Odyssey Elite (Wife's)
UmeshT is offline   Reply With Quote
Old January 28th, 2019, 09:12   #6
ESmith813
I've had my 1-2 shift grind a handful of times when it's cold unless I really really take my time between the shift. I've been driving stick for 10 years and the only car I've ever had grind gears at all was an old, old pickup with known faulty synchros. I'm thinking of taking it to the dealer under CPO while it's still cold out.
Old January 28th, 2019, 21:34   #7
sportwagen3
Yeah it only grinds when it's cold outside just like you said. Let me know what the dealer does if you take it in.
Old February 6th, 2019, 04:58   #8
Scott02
TDI(s): Too Many
Fuel Economy: 51/45/41
This is the nature of thicker transmission lube when it's cold out. Drive more, worry less.
2015 GSW DSG - 27kmi, Kerma engine tune
2011 JSW DSG - 160kmi, Malone DSG tune - Buyback done
03 Jetta Wagon TDI 5MT - 175kmi, 2.5"F 2"R lift, 215/75r15 tires, self tuned
02 allroad TDI 6MT - 150kmi, current project, getting a BSM deleted BHW and euro TDI geared 01E quattro
Scott02 is offline   Reply With Quote
Old February 10th, 2019, 08:02   #9
adjat84th
adjat84th's Avatar
1-2 when cold is very notchy. Definitely have to slow it down till it warms up a bit. The gear lube in these is incredibly thin, so I think it's just the design of the synchros. They use a friction material applied to the rings rather than a ridged ring to grab the gear and slow it down. The friction material likely doesn't slow the gear down as fast especially when cold.
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTD1752vrk, 4bar MAP, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
Old February 11th, 2019, 16:13   #10
paperthin
TDI(s): 15 A3 TDI
On my previous MT 09 jetta i changed the fluid to a redline product which made a world of difference during the cold temps. I changed it because of mileage, but a positive change came out of it. I had the same problem with the VW fliud.
2009 Jetta TDI (bought back), 2015 A3 TDI (current)
paperthin is offline   Reply With Quote
Old February 12th, 2019, 11:19   #11
nkgagne
Fuel Economy: See Fuelly in signature
Simple solution: double-clutch when the car is super cold.
It's made a bit more difficult by the thicker fluid in the clutch circuit when super cold (the pedal doesn't want to return as quickly). After driving a little while, you will feel when the gearbox begins to loosen up, and then you can go back to single-clutching, starting with higher gears, then finally for lower gears.
Accelerating goes like this: Accelerating in 1, lift off/clutch/shift to N, release clutch as the revs fall, clutch/shift to 2 (should easily engage), release clutch and accelerate in 2, repeat 2-3, 3-4. 4-5 and 5-6 are usually close enough not to require more than just a slow shift, plus if it's icy out...
Decelerating (from 4, for illustration): slowing in 4, clutch/shift to N, blip the accelerator while briefly releasing the clutch, clutch/shift to 3 and release clutch quickly before revs fall. All while braking as required (double-clutch heel-toe). Repeat 3-2, and 2-1, with a bigger accelerator blip each time (gears are spaced farther the lower you go). Note: you may have an easier time using this technique to go 2-1 while still rolling instead of hitting 1 from a stop when extremely cold. I know I do!
Note: "release the clutch" above means to do so in a deliberate snap. Slow and easy is not your friend with this technique.
If you're doing this correctly, the second half of the shift should happen with very little resistance. For added smoothness, you can also *slightly* bring up the RPM after your shift is complete if it has fallen below the ideal RPM for the next gear (applies to upshifts more than downshifts, since one has to wait for the RPM to fall enough while in N for the next higher gear to match, so by the time the gear is actually engaged the RPM's have then fallen too low, resulting in a lurch upon clutch release; during downshifting one is usually also slowing down, so the 300-500 rpm loss after the blip while you engage the next gear is more-or-less accounted for by the slower car speed.
In my old Mk4, I changed to GM Synchromesh fluid which aided greatly with cold-weather shifting (all shifting, really, that stuff was amazing), but I have not researched if it also compatible with the Mk7 gearbox...
Bone stock. Dieselgate Stage 1 reflash complete.
nkgagne is offline   Reply With Quote
DSG Hard Shifts and Bucking out of/into 1st TDI Stevestr VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 43 April 20th, 2016 09:16
02 auto hard shifts 2nd to 3rd when warm jkaiser VW MKIV-A4 TDIs (VE and PD) 2 January 7th, 2012 06:07
2004 09A Hard Cold Shifts FordGuy100 VW MKIV-A4 TDIs (VE and PD) 3 December 20th, 2011 11:12
DSG Harsh shifts 1st to 2nd? fgbrault VW MKV-A5 Golf/Jettas 33 October 11th, 2009 12:26
Automatic Trans violently shifts into 2nd on cold engine rgruber VW MKIV-A4 TDIs (VE and PD) 7 December 31st, 2002 07:45
Page generated in 0.14234 seconds with 11 queries
[Output: 103.87 Kb. compressed to 88.20 Kb. by saving 15.67 Kb. (15.09%)]
