While you wait for warmer weather try to find a local VCDS and recheck after
X2. Or if this is a long term project, spend the $200 and get the VCDS entheusiast package/cable. Gives you access to use VCDS on up to 3 VINs.
It'll pay for itself the second you need a new key matched to the car.
For the speculators welcome part:
What temps? Cold weather could actually cause the misfire(sends code) but immediately settles itself out.
Also, I dont recognize that as 5 codes. Maybe i over think this, but code 3 is the basic way of expressing the following two codes(4 and 5)
Or simply, 4 and 5 are explaining what code 3 is, specifically. (Not exactly helpful statement, but may ease your mind from thinking a thousand things are wrong)
Did you say the car sat for 2 years? Could be old fuel, or summer fuel with no anti gel agents? Thus, cold temps cause problems.
Sent from my VS987 using Tapatalk
