Old January 11th, 2019, 14:16   #1
midairmark
midairmark's Avatar
Fuel Economy: 55-60 MPG-6 speed
Default Idiot me, put in wrong oil month ago, OK to leave?
Well I screwed up my last oil change, didn't look at the label and put the wrong oil in. I usually use Mobil 1 full syn. truck diesel, 5w-40. I had a lot of my mind about having a car transported and just picked up the wrong container. I put in Mobil 1 full syn. 5w-30 for the wife's gas car. I didn't notice until today, when I went to change her oil and noticed I had a full gallon of diesel oil, unopened!
I have been driving the car at least 3 weeks with that oil in it. I don't beat the car, just transportation and I don't rev it higher than 2500 usually. It has 237k miles on it, 01 Jetta.
Do you think I need to change the oil out or do you think it is OK until next oil change?
Thanks,
Mark
midairmark is offline   Reply With Quote
Old January 11th, 2019, 14:21   #2
KLXD
You know what they say about opinions but here's mine: Drive it.
Before I knew better I used plain ole 10-30 in my '98. Prolly for at least 50k. It's now got over 350k.
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
Old January 11th, 2019, 15:09   #3
1.4TDI PD
I think you will be just fine. In the long run you want to put 5W-40 but once or twice shouldn"t do any damage to your engine i have been runing 5W-30 on a couple of engines before i realized i should switch to 5W-40 to minimize engine wear. And they are all still runing strong.
Audi A4 B6 Avant 2.5TDI Quattro tiptronic, Audi A8 D2 3.3TDI Quattro tiptronic.
1.4TDI PD is offline   Reply With Quote
Old January 11th, 2019, 15:49   #4
midairmark
midairmark's Avatar
OK, thanks guys.
Old January 11th, 2019, 18:02   #5
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
I would get that oil out ASAP. It not rated for compression ignition engines and cannot handle soot. It will cause very high engine wear. The 30wt will not do the flat tappet cam any good either.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old January 11th, 2019, 18:34   #6
Owain@malonetuning
I'd swap it, probably won't do much harm but no sense risking it. On the plus side I guess that counts as an engine flush.
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is offline   Reply With Quote
Old January 11th, 2019, 18:47   #7
Good Ol' Boy
VeeDubTDI's Avatar
Add me to the "change it" camp.
Old January 11th, 2019, 18:53   #8
Mongler98
yea, before i found this site, about 2 full years, maybe 95K of just cheep full synthetic 5-30 in what ever gave me the biggest rebate.
your fine.
In fact you could keep useing it, but im a stickler and would insist you change it out back to 5-40 diesel mobile one on your next oil change. dude your fine.
Old January 11th, 2019, 22:58   #9
flee
Fuel Economy: 40-ish
I did the same thing with some Mobil1 non-diesel oil. I just sucked it out and kept it
to top up our various gas burners. There may be a quart or 2 lying around here still.
I only drove about 45 miles on it and so I didn't want to waste it.
Didn't bother changing the filter.
2002 Jetta GLS TDI wagon
flee is offline   Reply With Quote
Old January 12th, 2019, 05:38   #10
AndyBees
AndyBees's Avatar
I avoided chemistry in HS and college.... and may have stayed in a Holiday Inn last night.
Having said that, here's my opinion.
Today's modern full synthetic oils rated for gasoline engines are likely much better than what was dumped into diesel engines 50 or 60 years ago.
The immediate concern is the Turbo shaft........ don't want any coking. However, I suspect the gasoline rated synthetic oil can handle that heat as it probably meets specs for the VW 1.8T which runs a hell of lot hotter than any TDI Turbo.
Yes, like KLXD stated and others, I did the same thing in the 40k to 50k mile range with my 2000 Jetta...... fast forward to the present. My son now owns it and it is doing just fine with over 370k miles on the clock.
Handling the soot just means the oil keeps it in suspension, thus no to very little settling out............ hey, what's that filter for?
Yes, I'd likely change that oil out a little sooner than normal ........ then drive more and worry less!
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
AndyBees is online now   Reply With Quote
Old January 13th, 2019, 09:00   #11
midairmark
midairmark's Avatar
Thanks for the input.
Old January 14th, 2019, 10:37   #12
andreigbs
I'd consider it an engine flush type of oil and replace it with the proper full synth diesel rated oil, then motor on.
2014 Jetta TDI // 20xxx miles // 39 MPG & 2014 GLK 250 // 88xxx miles // 37 MPG
2014 Golf TDI // 45xxx miles // 38 MPG - buyback'ed
2004 Bora TDI // 146xxx miles // 42 MPG - sold
1997 Jetta TDI // 317xxx miles // 44 MPG - sold
1986 Golf Diesel // 224xxx miles // 48 MPG - totaled
andreigbs is offline   Reply With Quote
Old January 16th, 2019, 18:39   #13
midairmark
midairmark's Avatar
How about adding a diesel oil additive, to give the current oil additional protection aka Slick 50 (for example), instead of changing it out? What is recommended as a good oil additive?
Old January 16th, 2019, 19:37   #14
jettawreck
jettawreck's Avatar
No. Resist the urge to overthink it. Leave it be or if it bothers you, change it. But leave the "additives" out.
2004 Cadillac SLS (wife's)
jettawreck is online now   Reply With Quote
Old January 16th, 2019, 19:50   #15
turbobrick240
turbobrick240's Avatar
Yeah, forget the slick50. You could get a quart of mobil1 15w50 for topping up though. That would thicken up the 5w30 and add some zinc. It's a tough engine, just keep it full of oil and you'll probably be fine.
turbobrick240 is online now   Reply With Quote
Did I put the wrong oil in my TDI? bestsilverjetta Fuels & Lubricants 15 July 8th, 2017 04:02
Shop put the wrong oil in... 16vjohn VW MKIII-A3/B4 TDIs 8 February 19th, 2012 17:04
I think stealershhip put in wrong oil.... Dean VW B5 Passat TDIs 17 September 29th, 2011 00:02
5 years, 1 month, 3 days ago NewTdi West Coast Canada/USA 25 January 12th, 2009 19:51
Page generated in 0.16613 seconds with 11 queries
[Output: 126.65 Kb. compressed to 105.55 Kb. by saving 21.11 Kb. (16.67%)]
