Old January 9th, 2019, 23:35   #1
CornDog73
TDI(s): 2011 JSW
Default Timing Belt Age
I know the maintenance schedule states 130k for timing belt, but my TDI is 8 years old (it's a 2011 model) with 43k on the odometer. Should I consider replacing it? Thank you for any advice.
CornDog73 is offline   Reply With Quote
Old January 10th, 2019, 18:02   #2
Manbreathesdiesel
TDI(s): MK6 Golf M6
Fuel Economy: 5.3L/100
I’d replace it honestly. I bought my 2011 with 145000kms (not sure what that works out to in miles), but I pulled the timing cover off and took a look at the belt. Didn’t look terrible, but I still replaced it. Timing belt is a lot cheaper to do then replacing a head or block.
I bought a full timing belt kit from Rockauto, with the metal impeller water pump, think my total was $316 Canadian. Dealer charged me just shy of 600 to put it in.
Manbreathesdiesel is offline   Reply With Quote
Old January 10th, 2019, 18:08   #3
TDI smile
TDI smile's Avatar
Change it....HURRY UP!!!
TDI smile is offline   Reply With Quote
Old January 10th, 2019, 19:09   #4
vincej
If it were mine I wouldn't even think of changing it.
vincej is offline   Reply With Quote
Old January 10th, 2019, 19:33   #5
turbobrick240
turbobrick240's Avatar
When was the emissions fix applied? The engine is covered by the extended warranty that comes with the fix. I'd wait until the warranty is nearly expired before giving it any thought.
Old January 11th, 2019, 20:57   #6
KeyTDI
DieselGeek kit.
KeyTDI is offline   Reply With Quote
Old January 11th, 2019, 22:05   #7
vincej
I have a kids 04 Focus wagon 137000kms/85000mi with a change interval of 120000miles. Maybe I will be conservative and change the belt at 100000 miles if they don't destroy it before then.
Old January 12th, 2019, 06:30   #8
ihatespeed
Fuel Economy: 40mpg city 46 avg, 50 hwy 33 trailer
If you are thinking about doing it its cheap insurance, you can rent the special tools and with a bit of patience and basic hand tools (plus the triple square drivers) you can do it in your driveway. check out the instructions on my turbo diesel or the guide here, Ive done 2 and its real straightforward. As you do not know if the car got its 45000 miles sitting in traffic on the 405 baking in the sun or getting driven to town by grandma once a week in the middle of rural temperate America, there really is no telling how hard a life your timing belt has lived. I would guess with tool rental, coolant and a kit you can DIY for less than 450.
Andrew's 3rd generation (2Micron.com) return fuel filter, and Pure Flow HPFP modification, timing belt guard and the full Malone flashzilla / Buzzken stage2.0 eco treatment (bosal hitch and heavy springs for towing)
ihatespeed is offline   Reply With Quote
Old January 12th, 2019, 10:42   #9
turbobrick240
The timing belts on the common rail tdi's are of extremely durable carbon aramid and Kevlar construction. The few failures I've heard about were caused by a failed serpentine belt that derailed the tb. In general, tdi tb failures are mostly caused by failed tensioners, water pumps, and rollers- not a degraded belt. I don't know how much of a factor age is in degradation of those parts, but I suspect it's not a lot.
Originally Posted by oilhammer View Post
It'll be fine, run it, don't worry about it. If it hits a decade since leaving the factory before you hit the mileage, then I'd go ahead and change it.
Every CBEA and CJAA timing belt I have taken off, even those with far beyond the mileage interval, looked perfectly fine. Looks don't tell you a whole lot, especially on these newer belts with the textured back side.
Obviously be aware of things like any strange noises, as well as the condition of the accessory belt, and if for some reason you need to go in there for something then you may end up doing it sooner (seeping water pump, for instance) but otherwise I'd just enjoy the car.
Age of Timing Belt, not miles? tdiblair VW B5 Passat TDIs 38 January 18th, 2016 19:21
Timing belt: Age vs. Mileage stagman Ontario 14 April 7th, 2012 16:17
Timing Belt age? pcguru TDI 101 10 March 23rd, 2012 16:22
timing belt, age vs. mileage zaq123 TDI 101 25 October 3rd, 2008 18:58
Timing Belt - Can Age Kill It? k1rod VW MKIV-A4 TDIs (VE and PD) 10 February 1st, 2005 08:16
Page generated in 0.14815 seconds with 11 queries
[Output: 89.29 Kb. compressed to 76.36 Kb. by saving 12.93 Kb. (14.48%)]
