Old January 18th, 2019, 07:37   #16
[486]
TDI(s): 02 golf ALH
Originally Posted by Geordi View Post
LOL... That's not what wet stacking is. Here's some reading for you.
https://www.ckpower.com/wet-stacking-avoid/
Tip: When an engine is operating at normal temps and normal loads and the exhaust system is dry but the INTAKE IS WET WITH OIL... That's not wet stacking. That's oil in the intake mixing with EGR soot.
What does the EGR do? Introduce exhaust into the intake.
What temperature does the intake and EGR cooler peak at? Well below that where the fuel coke will burn off.
See also: why is intake coking reduced markedly when you get a remap that eliminates EGR flow when the engine is dead cold?
See also as well: Engine oil does not dry to a hard coke, neither does your typical hot exhaust soot.
Third see also: why does the EGR cooler plug up? It sees no engine oil.
[486] is offline   Reply With Quote
Old January 18th, 2019, 11:25   #17
belome
Fuel Economy: 47'ish
Originally Posted by turbobrick240 View Post
It's probably free. I wouldn't use it if it shows any signs of containing moisture.
So, it is free... you are only mixing it 5% so how much are you really gonna save?
I mean, there are so many reason NOT to use it (especially in a CR) and virtually no gain by doing it.
The only thing I can pass is a fuel stop, but I'm OK with that.
My claim to fame - I was banned from VWVortex!
belome is offline   Reply With Quote
Old January 18th, 2019, 13:40   #18
turbobrick240
turbobrick240's Avatar
True. Adding a gallon per tank seems like more headache than it's worth. I'd be filling up cans to take home to my less finicky diesels.
Old January 18th, 2019, 17:44   #19
[486]
TDI(s): 02 golf ALH
Originally Posted by Ol'Rattler View Post
and given away
Who do I ask at the airport about getting free fuel without getting stuffed into a black van and sent to cuba?
Old January 18th, 2019, 20:29   #20
ZippyNH
Pilots on some airplanes must sump fuel on a daily basis... usually it's on smaller planes, and creates 1-2 gallons of fuel a week on a turboprop. Back in my feeder pilot days in a caravan, I usually had a gallon jug that I would empty weekly at the company hanger. Usually there are barrels it gets dumped into, then burnt in heaters for the hanger. Sometimes there are much larger volumes, but that is usually put back into the plane after the required repairs.
Pilots and mechanics have been burning it for years, but when emissions engines came to the diesel cars/trucks, made it much higher risk.
2015 Jetta TDI SE, Silk Blue
previous-2005 MINI Cooper S, tuned and modded to 200+ HP
ZippyNH is offline   Reply With Quote
Old January 19th, 2019, 15:06   #21
rennsportmotorrad
Fuel Economy: 48.5
I burn the Jet A in my salamander heater in the shop when it is cold, But I would never run it in my TDI, I thought some of my BMW motorcycle customers were cheap---but some of the people here take the cake. lol
rennsportmotorrad is offline   Reply With Quote
Old January 19th, 2019, 16:15   #22
turbobrick240
...says the guy driving a 15 year old diesel . I have a Saudi friend who couldn't understand why I'd buy a diesel car - apparently only ultra cheapskates buy them there.
Old January 19th, 2019, 22:23   #23
Geordi
Geordi's Avatar
Location: Somewhere between Heaven and Hell. But it is really hot here in S. Florida...
Yeah, but when they run out of gas there.... They can always just get a full tank buying another new car.
I always knew beans would give me gas. But I never expected Diesel!
Geordi is offline   Reply With Quote
Old January 20th, 2019, 09:51   #24
ghohouston
ghohouston's Avatar
Fuel Economy: 40 Mpg
I wouldn't run questionable fuel in a common rail, with a dpf. I, as well as people i know have ran strsight jet a, and had no adverse effects from it, but those were 7.3's, as well as ve pump engines.
2001 Silver Jetta Sedan TDI 5 Speed,3" Kerma turbo back straight pipe
Allard EGR Delete
Bosio DLC 764's. 1997 Ford F350 CCLB 7.3 Powerstroke Diesel ZF5, straight piped
ghohouston is offline   Reply With Quote
Old January 20th, 2019, 10:11   #25
[486]
TDI(s): 02 golf ALH
I think it is more that gas is probably the equivalent of a quarter a gallon there
like in venezuela
Old January 20th, 2019, 11:29   #26
turbobrick240
You'd think, right? But the per capita income in Saudi Arabia is about one third that of the US. The rich are very rich, but most are not rich.
Old January 22nd, 2019, 04:46   #27
Ol'Rattler
Ol'Rattler's Avatar
You wold have to know someone that is involved with maintenance in the hanger.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old January 22nd, 2019, 14:23   #28
piotrsko
piotrsko's Avatar
Fuel Economy: 46 city/56 hwy so far wonder what the Golf gets
Used to be at Mojave apt they would hand it out free when the big jets arrived and had to be defueled before storage. Bunch of Yahoo's buggered that up getting caught with it in their 6.9 &7.3's. Which pissed off caltrans. Sometimes if you ask the refuel people you can buy it depending on their mood and weather.
I myself would either use power service white or find some winter D1 at a truck stop because they dont have weird stuff in them.
piotrsko is offline   Reply With Quote
mixing oil and diesel phucking-low VW MKIV-A4 TDIs (VE and PD) 18 May 15th, 2011 15:42
anyone try mixing Bio diesel and Jet A fuel brianteel Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 35 March 6th, 2006 08:09
Mixing biodiesel with diesel #2 Fahrfuwerfuelen Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 31 January 10th, 2005 17:00
mixing types of diesel hollywooooooood TDI 101 2 October 20th, 2003 01:24
Mixing diesel and wvo RoyD Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 7 September 29th, 2002 19:31
Page generated in 0.17557 seconds with 11 queries
[Output: 121.04 Kb. compressed to 101.90 Kb. by saving 19.14 Kb. (15.81%)]
