Old January 7th, 2019, 16:03   #1
Defperformance811
Default CR 140 CJAA race pipe
Looking for a thread showing pictures and steps for install of a cr 140 egr/asv delete race pipe for a mk6 golf. I have looked but I cannot find one. Any help? I understand the removal of emissions parts is illegal and I am asking for a track car. Thanks.
Defperformance811 is offline   Reply With Quote
Old January 8th, 2019, 08:30   #2
sootchucker
sootchucker's Avatar
TDI(s): 2015 Golf
Fuel Economy: Good
SUPER easy... remove ASV and EGR valve, istall race pipe in its place and go!
Who says a Jetta can't roll coal???
sootchucker is offline   Reply With Quote
Old January 9th, 2019, 18:12   #3
CaptainAF
TDI(s): JSW 2014
Just wondering why delete it? What is gained?
CaptainAF is offline   Reply With Quote
Old January 9th, 2019, 22:15   #4
Defperformance811
There is a good read on it on the rawtek website. Helps reduce temps and also helps prevent sludge buildup. Additionally and the main reason I want it is that it comes with a boost tap directly off of it. I have a p3 multi gauge and it’s phenominal, however, when the Malone tune was written, the boost gets taken out of its slot. This means I am unable to read boost electronically. I have a tap but I have been too lazy to put the car on the lift, remove the pipe, and tap it and route it and then worry about a possible leak. Just takiing our the egr valve and asv and putting the pipe in place with the fitting would make it much easier. I was able to find the info I needed. Thank you!
Old January 19th, 2019, 14:04   #5
Terry270
I'm looking at installing a race pipe as well, which options have you found?
2003 2dr Golf TDI-R32 bumpers, sideskirts and wheels, VNT17
2010 Audi A3 TDI-CR170, Malone stg3, ARP headstuds, GLI Brakes, 2micron fuel and serpentine belt protection kits
Terry270 is offline   Reply With Quote
Old January 19th, 2019, 14:15   #6
Defperformance811
Rawtek and darkside offer kits that will allow you to eliminate either the egr or the egr/asv combo. Although I contacted darkside and they told me that their 57mm may not be direct fit because the stock hose may not reach.
Old January 19th, 2019, 14:21   #7
Geordi
Geordi's Avatar
Location: Somewhere between Heaven and Hell. But it is really hot here in S. Florida...
I installed a blanking plate on the factory pipe, makes access to the oil filter easier.
Please explain what you mean about the tune "removing the boost from its slot" b/c I have a scangauge and I can read both the expected and delivered boost right off the factory MAP sensor? I had to create an X-gauge, but it works fine.
I always knew beans would give me gas. But I never expected Diesel!
Geordi is offline   Reply With Quote
Old January 19th, 2019, 14:24   #8
Defperformance811
This is what P3 told me
Thank you for contacting us. We have found that the last round of Malone updates has moved the boost information from the OEM location in the ECU. We have confirmed this with Malone and are working on a solution for down the road that will not require the analog boost sensor.
For now, however, the only solution we have is to install the analog boost sensor. This will ensure that you have 100% accurate boost readings no matter what tunes or mods you run.
Old January 19th, 2019, 17:38   #9
Terry270
So it won't throw a CEL, just won't be able to read boost?
Old January 19th, 2019, 17:43   #10
Defperformance811
What won’t throw a CEL?
CR Race Pipe w/ASV delete - $50 shipped brian_e Private TDI Items for Sale/Wanted 3 May 23rd, 2018 15:12
cjaa race pipe available? iamatt TDI Power Enhancements 3 March 6th, 2018 14:15
CR Race Pipe psrumors Private TDI Items for Sale/Wanted 0 April 17th, 2017 18:28
Diesel Dubs CR Race Pipe Paulinski Private TDI Items for Sale/Wanted 3 December 26th, 2014 14:34
Cr 140 egr delete (cjaa) 13JETTAJSW Private TDI Items for Sale/Wanted 0 April 27th, 2014 08:31
Page generated in 0.11320 seconds with 11 queries
[Output: 94.91 Kb. compressed to 80.50 Kb. by saving 14.41 Kb. (15.19%)]
