Old January 9th, 2019, 08:08   #16
RIP TDI
That's why I'm asking pump leak victims to find out if dealers are replacing these with conventional, non-variable pumps. There are reports that that is the case and there appears to be a TSB on it, which makes sense with such a potentially disastrous failure. If true, it would be a shame to lose the extra quick warm-up feature of that pump, though, and as such, its probably considered an integral part of the emissions system. Perhaps an improved variable-flow pump is in the pipeline and a conventional pump is just a stop-gap measure until the redesigned one is available.
- Chris
'15 GSW SE 6MT, '01 Golf 5MT
'97 Passat sedan, '96 Passat variant
'99 BMW M3 Cabrio
RIP TDI is offline   Reply With Quote
Old January 9th, 2019, 11:09   #17
740GLE
I wouldn't hold my breath, but there's hope.
Hers: 2015 Passat SEL (NOS) w/ VW fix and Malone Stage 2 (low torque for DMF shudder).
Old January 9th, 2019, 11:14   #18
GreenLantern_TDI
GreenLantern_TDI's Avatar
Fuel Economy: Mid 40s
Id rather have no variable anything. Straight mechanical and no electrical. If your at 70000 miles and the variable water pump dies ya just as well do the whole TB job cause it would just cost alil bit more for parts.
2015 Golf SEL. Malone DSG Tune. H6 AGM East Penn Battery. Frost Heater. Ares Skid Plate. Fumoto Valve. PentoIII.
GreenLantern_TDI is offline   Reply With Quote
Old January 9th, 2019, 20:05   #19
bigb
When I have time I am going to pull the underbelly and see if I can poke a borescope up inside the timing cover anywhere and look for red stains. I was able to find a small leak on my Powerstoke this way before it got bad
bigb is offline   Reply With Quote
Old January 9th, 2019, 20:18   #20
bigb
Here is what appears to be a common failure mode for the variable flow water pump. The metal blocking sleeve is stuck in the activated "cold" position, covering the impeller blades; it should be sitting below the impeller in the normally open rest position.
This failure would, of course, cause overheating. Don't know whether early pump external leakage would contribute to this sleeve seizure at a later date.
And the service training pdf assures that this won't happpen
Old January 9th, 2019, 21:04   #21
BamaB4S
BamaB4S's Avatar
Fuel Economy: 42/47/52 mpg
This ^^
Reminds me of the variable adjusting suspension they put in the Lincoln. Good intentions but poorly engineered - designed to fail and costly to repair.
BamaB4S is offline   Reply With Quote
Old January 10th, 2019, 23:01   #22
TDI WNY
I won't know status of my vehicles repair till Saturday. According to the dealer the part hasn't arrived. ? I'll update as soon as I know something.
TDI WNY is offline   Reply With Quote
Old January 11th, 2019, 19:33   #23
tdidieselbobny
tdidieselbobny's Avatar
Which dealer did you take it to? Northtown, Towne, Basil, or Orchard Park?
97 Passat TDI-420,688 miles,totalled by 86yr.old lady-gone,but not forgotten:mad-'15 Silk Blue Golf Sportwagen w/DSG, 43k miles....'16 Kubota BX1870 MMM/FEL, 260hrs-And now an '03 Jetta TDI 5spd w/ 443k,RC2,Sprint 520's,Dieselgeek short shifter , totaled 10/13/19 by a stupid deer, back alive 11/4/19....
tdidieselbobny is offline   Reply With Quote
Old January 12th, 2019, 15:47   #24
TDI WNY
Just got my car back from Basil. The new pump which they said took longer to receive than expected is 04L-121-011-L. The service writer didn't know the difference between variable flow or constant flow and said he did ask the tech. I have 39010 miles on my odometer, fully covered no charge repair under normal powertrain warranty. The car heats up normally.
Old January 12th, 2019, 16:19   #25
xabjw4
Fuel Economy: to 3,000 miles, 46 mpg tops
2015 Golf SW TDI. My tank was low a few times. They found a crack in the side of the radiator tank on the left drivers side. Replaced in for free, no more problems, maintains level between the low and normal line.
xabjw4 is offline   Reply With Quote
Old January 12th, 2019, 18:04   #26
bigb
Just got my car back from Basil. Northtown doesn't like replacing all of the belly pan screws. I've never been to Orchard Park or Towne since they bought Schmidt's. The new pump which they said took longer to receive than expected is 04L-121-011-L. According to Chris Bell this is the non variable pump. The service writer didn't know the difference and said he did ask the tech. There was no charge, no car wash and no breakfast bagels/doughnuts. I am curious where WNYers' take their TDIs to? Northtown, Towne, Basil, or Orchard Park? Reviews run 10% unhappy for every dealer around here.
Please let us know if you notice any longer warm-up time due to the non-variable pump. Are you still under the 3/36 warranty?
Old January 12th, 2019, 18:28   #27
RIP TDI
Actually we still don't know which pump that is. Whether that number is already a super-cession or the part is a redesign without a new p/n isn't clear. Dealer online parts catalogs only list 04L121011L and 04L121011EX which is the same part but rebuilt vs. new.
Only a visual would have confirmed which pump this is.
- Chris
'99 BMW M3 Cabrio
Old January 13th, 2019, 07:06   #28
Z85rado
We had the red triangle show on Thanksgiving day... while already late. Checked coolant and it was a hair below the sensor. It only makes an appearance on cold cold days after the vehicle has sat over night. I just ordered an oil change kit and coolant from IDPARTS to top it off. I'll keep an eye on it from there. 28.5K on ours. Need to go to the dealer for the passenger side rear window being INOP, I will have them check it at that point.
I did the 20k and will do the oil soon so this doesn't see a dealer often.
Z85rado is offline   Reply With Quote
Old January 13th, 2019, 09:46   #29
TDI WNY
I have 39010 on the odometer. Repair covered under powertrain warranty. Warm up time seems normal.
Old January 14th, 2019, 19:43   #30
tdidieselbobny
I've only taken car to where I bought it from, Dorschel in Rochester. They've treated me pretty decent so far. They gave me a loaner for the phase 2 fix, wasn't sure if it was gonna be complete or partial, ended up being partial plus horn replacement, and didn't charge me for loaner.
03 Golf Coolant loss, Overheat, Oil in Coolant BatCobra TDI 101 19 September 12th, 2015 20:52
Coolant Loss JOmax VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 4 November 10th, 2013 21:36
Rapid coolant loss in cold weather extemely slow to no loss in warm/hot weather cdc TDI 101 0 June 23rd, 2011 15:23
Slight coolant loss, coolant smell in cab rampage TDI 101 6 July 15th, 2008 14:35
coolant loss elan VW B5 Passat TDIs 11 July 9th, 2008 11:11
Page generated in 0.18467 seconds with 11 queries
[Output: 128.92 Kb. compressed to 107.90 Kb. by saving 21.02 Kb. (16.31%)]
