Old January 15th, 2019, 17:08   #61
Cuzoe
TDI(s): MK7 Golf S
And for some laughs, the opposite of a big brake kit, haha... I've got to get the rear power pack brakes installed ASAP.
Sent from my ONEPLUS A6013 using Tapatalk
Cuzoe is offline   Reply With Quote
Old January 15th, 2019, 17:20   #62
turbobrick240
turbobrick240's Avatar
I'm sure I'm in the minority, but I actually think the daylight coming through an open wheel with stock brakes looks cool. The track ready look is cool too, but not cheap.
Old January 15th, 2019, 21:11   #63
Cuzoe
TDI(s): MK7 Golf S
I think my wheel gap says "I'm not going to the track" but I see the appeal of seeing light through the wheels. Certainly wasn't cheap considering it's purely aesthetic for me but the Rotorlabs kit is a great deal. The 17z kit I bought runs $825 (includes mounting hardware, calipers and rotors). Pads were about $50, brake lines $75 and spacers around $75. Figure another $50-60 for shipping and you're still under $1100 excluding labor. The 18z kit is $150 more.
Old January 15th, 2019, 21:55   #64
turbobrick240
I have a feeling that fender gap won't be hanging around for long. I just went from a lowered golf on sport springs(stiff) and 17's, to a stock golf on 15's and must admit the ride is much more comfortable. Maybe I'll feel differently once summer rolls around.
Old January 16th, 2019, 15:18   #65
Cuzoe
TDI(s): MK7 Golf S
Originally Posted by turbobrick240 View Post
I have a feeling that fender gap won't be hanging around for long...
You might be surprised, I went from H&R's back to this at the same time the brakes were installed. Added 034 Motorsports fixed camber mounts too but they're coming off next chance I get.
Old January 17th, 2019, 16:58   #66
adjat84th
adjat84th's Avatar
I may try to install this weekend. You say the brake lines worked perfect, were they able to be clipped into an existing mounting tab to keep from flapping around?
Sent from my Pixel 2 using Tapatalk
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTB2260vklr, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
Old January 17th, 2019, 18:03   #67
PB_NB
PB_NB's Avatar
I going to have a look at a LBK too . I have my BBK tucked into my 19" BBS's. The rear kit is almost as big as the fronts.
Crazy stopping power even with the trailer attached.
1999 New Beetle TDI - Bosio 1019's, Malone S4, Skid Plate, Neuspeed Sway Bars, KW V2, 19's BBS-CH, Spyder LED's, EGR Delete, VF Mounts, South Bend Clutch, B&M Shift Kit, VNT17, Custom Side Mount Intercooler, HPA Big Brakes 355mm Ft/335mm Rr, 2.5" Custom SS Straight Through Exhaust, Colt Stage 2 Cam, 3 Bar Map.
PB_NB is offline   Reply With Quote
Old January 17th, 2019, 19:32   #68
Cuzoe
TDI(s): MK7 Golf S
Yes they were, same place as the factory lines. I'll pull a wheel off at some point this weekend and snap a picture.
Old January 20th, 2019, 13:13   #69
Cuzoe
TDI(s): MK7 Golf S
MK4 R32 brake lines up front, secured in the factory location.
Old May 5th, 2019, 10:24   #70
adjat84th
adjat84th's Avatar
Finally getting around to installing these. I must have picked up the wrong R32 lines. Mine don't have an inline clipping point as yours do in the picture. And, they appear too short as well. Do you recall exactly which pair you got and where by chance? Mine came from USP and have the conical seat but are certainly different.
Old May 5th, 2019, 10:33   #71
Cuzoe
TDI(s): MK7 Golf S
Interesting, mine came from USP also. I wonder if they sent you rears by mistake. Screenshot of my order...
Old May 5th, 2019, 10:58   #72
adjat84th
adjat84th's Avatar
I see where I messed up. I ordered the Mk4 R32 conversion lines for non R32 models upgrading to the R32 brakes. Oh well, correct ones ordered. I'm still going through with the install to the point of needing the lines installed. Hopefully by Wednesday I'll have them.
Old May 5th, 2019, 18:55   #73
Cuzoe
TDI(s): MK7 Golf S
Ahh, easy fix then. Let me know how the 18z fit. I still haven't found a real solution to my driver side caliper not being centered over the rotor. Currently the outboard brake pad has been shaved down by a couple mil to fit. This doesn't concern me because the pads are really thick and I drive less than 100 miles a week. That being said I intend to check the pads, that one in particular, once a month to make sure nothing sneaks up on me.
Rob at RotorLabs believes there is a difference in my car's hub/bearing assemblies or knuckles but I'm not buying that the tolerances on these are that loose. I suspect there's an issue with that caliper or (hopefully) rotor offset. I have a spare set of rotors on hand, ordered from rotorlab. At some point here soon I'm going to pull both calipers off and take a bunch of measurements.
I'll end my rant with a question. I still haven't installed the rear PP brakes on my car. I need brake lines that are 2-3" longer than stock PP lines. I know the caliper side uses a 12mm banjo bolt but I don't know the fitting for the car side. Does anyone know what type it is?
Old May 6th, 2019, 07:42   #74
adjat84th
adjat84th's Avatar
The 18z fit with just one washer between them and the mounting tab. That pulled the caliper inboard and centered as close as it's going to be unless I source some thinner spacers. This also gave me about 2.5mm extra clearance with my wheels which otherwise would have needed spacers. The rotors are within about 1-1.5mm of center and pads have plenty of room. They're both installed and ready to go, just need to install new lines when they come in and bleed the whole car as it was due anyway.
Here's a pic of the wheel clearance and some other shots. Hope to be running by Wednesday and I'll have a few more pulled back pics with a fresh wash
Old May 6th, 2019, 16:05   #75
Cuzoe
TDI(s): MK7 Golf S
They look great... my clearance is similar although I needed spacers. My problem with the driver side caliper is that it's too far inboard already. My mounting tabs are "too thick" which can't be fixed with washers unfortunately.
Did you end up buying the brake booster to go with the master cylinder? I haven't yet but pedal feels fine. I should do it when I add the PP rear brakes though.
For Sale: MK7 Stainless steel foot pedals(gas, brake and clutch) Nutty 5.0 Private TDI Items for Sale/Wanted 2 February 27th, 2017 09:19
MK7 2.0TDI oil pan upgrade options? _Blade_ TDI Power Enhancements 7 October 31st, 2016 04:36
Mk3/B4 Brake Upgrade: Corrado G60 Brake Calipers and Carriers 65k miles G60ING Private TDI Items for Sale/Wanted 4 September 2nd, 2009 05:28
Brake Upgrade 1sparrow Upgrades (non TDI Engine related) 19 January 7th, 2009 07:53
Page generated in 0.24991 seconds with 11 queries
[Output: 129.45 Kb. compressed to 108.58 Kb. by saving 20.87 Kb. (16.12%)]
