Old January 12th, 2019, 17:34   #31
theomarakas
TDI(s): 2013 JSW
Default Odyssey battery
My battery for 2013 Jetta Sportwagen TDI croaked. It is the original battery 6 years old with 19,000 miles. Always on trickle charger. I'm suspecting that the trickle charger killed the battery. for the last year I've been watching it charging erratically, I'm suspecting that it may have dried out the battery even though I see some fluid through the sight glass but it did feel kinda lighter when I pulled it out of the car. I doubt that I got any stronger, by the way....
I ordered an Odyssey battery, 34-PC1500T for $300. Yes, very expensive. My co-worker who is a pilot for 30 years swears by them. Money isn't so important, I hate being stuck and waiting for a jump or a tow. I'm sure it will be a rainy or snowy cold day, in the middle of nowhere at night. Murphy's law. So I decided to beat the odds by getting the best battery out there, or at least the most respected brand. Can the best fail? sure they can, anything can happen. However, your chances of surviving all of the above may be better. AMEN !!!
theomarakas is offline   Reply With Quote
Old January 13th, 2019, 10:38   #32
vincej
Batteries should be checked that the liquid does not fall below the top of the plates.
12.65 volts is 100%, less than 12 is discharged.
With car running the alternator should be charging at 14 to 14 1/2 volts across the battery terminals.
I think I'll go out and buy a replacement battery for my Rambler today from Costco.
It will be to replace the 21 year old Motorcraft that is in it now.
Or maybe I'll go and check its voltage first.
vincej is offline   Reply With Quote
battery ah ? golf tdi vw754 VW MKV-A5 Golf/Jettas 0 April 23rd, 2011 02:56
2004 Golf TDi Battery Drain xlch1920 VW MKIV-A4 TDIs (VE and PD) 9 October 7th, 2010 13:57
Battery problem ? Golf 2004 TDI vic_seadog VW MKIV-A4 TDIs (VE and PD) 29 September 3rd, 2010 09:57
Battery warranty for a 2000 Golf TDI? TDI-NC VW MKIV-A4 TDIs (VE and PD) 3 July 20th, 2004 16:23
Page generated in 0.13614 seconds with 11 queries
[Output: 53.83 Kb. compressed to 49.72 Kb. by saving 4.12 Kb. (7.64%)]
