Old December 17th, 2010, 09:37   #16
ToeBall
A trick I picked up from my Cummins manual is to restrict airflow through the intercooler and radiator by about 15% when it's very cold. This does reduce efficiency slightly but it also keeps the moisture in the air charge suspended so it can't build up in the IC and cause such problems. This also lets the engine get up to and hold temp better. I used to park pointing at brick walls when sleeping in the truck in the cold so the engine could maintain temp. I'd leave it idling all night for the heat.
2010 VW JSW TDI "Barley", 6-speed manual, Blue Graphite - 255/40's on 18x8's, Sigma6, B&M Shifter, Malone Stage 2, Koni coilovers w/H&R springs, 28mm front/27mm rear swaybars, GTD Grill, 900W stereo, PDE downpipe, Banks exhaust, APR intake, Votex kit.
ToeBall is offline   Reply With Quote
Old December 17th, 2010, 09:43   #17
Ryephile
Ryephile's Avatar
TDI(s): MkVI Golf
Interesting. I've had a lot of intercooled gas engines over the years but never even heard of an IC collecting anything besides PCV residue. The IC and plumbing position on the VW must be magical so all the condensate ends up trapped in the bottom of the IC.
I wonder if the EGT plays a part in the collection too.
'11 Golf TDI :: 6MT 4DR :: Reflex Silver
KW Variant 1 coil-overs :: VW Mud Flaps :: Frost Heater :: Opti-Lube + B2
Ryephile is offline   Reply With Quote
Old December 17th, 2010, 09:47   #18
Ski in NC
Fuel Economy: 48-52 typical
Steeper gear ratio may have something to do with it. The new cr engines run a good bit lower rpm on the highway. Turbo is probably making a good bit of boost where an ALH would not. So the intercooler flow has a better chance of seeing its moisture content cross the saturation line and condense.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old December 17th, 2010, 09:49   #19
740GLE
a visual representation of where the intercooler is in relation to the EGRs and turbos for a better idea of what going on. If the dealer bocks and says you forded a river, ask to see the intake filer and if it's wet then ask him how water got in.
I think it's an issue with frosting after the temp pressure change with the turbo and intercooler working too good. A possible soultion would be blocking off the intercooler with some plastic, that'd also help warm up temps. Kinda similar to a "winter front" that you could put on when you put on your snow tires.
It's take some experimenting and adjusting to see what your intake temps would be with part if not all the intercooler blocked off.
Old December 17th, 2010, 09:51   #20
740GLE
It's only making boost when called for, on the highway flat ground, no headwind at 70 you're not creating anymore boost than an ALH i imagine.
Old December 17th, 2010, 09:58   #21
bdisco
bdisco's Avatar
The inter-cooler for both my Subies were TMIC, not the coolest place in the engine compartment but...
^ this pic is ugly. Don't know about you but the only thing I want in my intake is nice cool fresh air. My '00 F250 7.3 can be hard to start sometimes but it is a little bigger. Looks like VW may have a design flaw. Installing a drain might fix the problem but dripping oily sludge won't make us popular with Greenpeace.
So when the Dealer tells you "Don't worry, that's normal, they all do that." , they're not lying.
bdisco is offline   Reply With Quote
Old December 17th, 2010, 10:02   #22
740GLE
this one's mine last Feb at 10K service
Old December 17th, 2010, 10:07   #23
VarmintSlayer
VarmintSlayer's Avatar
Possible side affect of an active dpf regen?
2009 Jetta TDI 6spd manual 320,000 kms
2001 Jetta GLS TDI auto r.i.p.
VarmintSlayer is offline   Reply With Quote
Old December 17th, 2010, 10:08   #24
IFRCFI
IFRCFI's Avatar
Thumbs down
Anybody else ever owned a new car that you have to manage what weather conditions you drive it in....? Yup...me neither...
IFRCFI is offline   Reply With Quote
Old December 17th, 2010, 10:20   #25
tcp_ip_dude
tcp_ip_dude's Avatar
Fuel Economy: 46@75mph/51@60mph/City 38mpg
Hehe. No, just aircraft. No doubt we'll have a POH checklist with 'Intercooler Heat' soon (i.e. like Carb Heat).
______________________________
'10 Jetta 6M Sedan, 35% Llumar tint, WeatherTech Floor Liners, TDIclub Plate Frame, B2, PS, ScanGauge II, Micro-Can VAG-Com
tcp_ip_dude is offline   Reply With Quote
Old December 17th, 2010, 10:23   #26
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
Originally Posted by PaulGiz View Post
I smell a recall.
You're an optimist...
Yuri
Quando omni flunkus moritati
ymz is offline   Reply With Quote
Old December 17th, 2010, 10:24   #27
53 willys
53 willys's Avatar
wow thats nasty!!! I dont want my engine taking in that shizz...i'm a bit disappointed to see that on a 2010 with 10k....
~2010 SportWagen~6sp Manual~
~Votex~Black Portos~H&R Sport~Diesel Geek Skid~Stage 3/CR 170 Turbo
HPFP Failures=1st @ 47,000 miles
Stock Turbo Failure 142,000
53 willys is offline   Reply With Quote
Old December 17th, 2010, 10:39   #28
IFRCFI
IFRCFI's Avatar
Originally Posted by tcp_ip_dude View Post
Hehe. No, just aircraft. .
+1. The baby poop looking brown stuff looks like what comes out of the breather tube on my 182. I'm used to cleaning it off the hangar floor...perhaps it will end up on my garage floor at home...
Old December 17th, 2010, 10:51   #29
GraniteRooster
GraniteRooster's Avatar
TDI(s): '12 JSW 6MT
Fuel Economy: 41 Winter | 45 Summer
Default A Little Quick Math
OK - so I've been doing a little quick Math:
2.0L Engine
0.5L Cylinder volume
18:1 Compression Ratio
Therefore:
Volume of Cylinder @ TDC = 0.5L/18 = 27.8mL or 0.94 US fluid ounces.
IT TAKES LESS THAN ONE OUNCE OF WATER TO HYDROLOCK A CYLINDER.
Many people have reported a cup (8 ounces!!) or more of water and/or ice draining from the intercooler low spots, and my dealer described my vehicle as draining "well over a cup of water & ice." (Before writing it up as 1/3 cup on my service history - thanks alot.)
This does not give me a warm fuzzy feeling inside.
GraniteRooster is offline   Reply With Quote
Old December 17th, 2010, 11:05   #30
DIESEL DAZZLER
Default Iced IC
One byproduct of combustion is water vapor.Low pressure EGR in a CRD is sent thru the inter cooler,so water condenses faster in colder weather in the IC and not so much when warmer.Also air is pumped into the crank case by the vac pump.
On my BRM 06 Jettta I have a catch can in the CC vent system it regularly fills with water, at least a cup every 2 weeks.
So far I have no issues with the IC on my 09 CRD.
09 Jetta TDI 3 pedal 6spd
06 Jetta TDI 3 pedal 5spd
03 Jetta TDI 3 pedal 5spd ,smf ,vr6pp,205's Egt boost gage
81 CADDY AHU,FMIC,11mil ,R 520's,RC2/3/4,Hybrid turbo [ 22v/sprinter inards] Peliquin Diff,air ride.
Kabota Diesel mower
DIESEL DAZZLER is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
notagearhead
Golf tdi 99 hard start from cold and yesterday won't start at all deep_sing VW MKIV-A4 TDIs (VE and PD) 17 December 13th, 2013 07:48
TDi 130 PD - Hard Start When Cold, No Start When Hot ginboomerang VW MKIV-A4 TDIs (VE and PD) 5 July 12th, 2011 12:36
Hard Start Plus Check Engine Light and Blinking Glow Plug Indicator Greg_Morgan VW MKIV-A4 TDIs (VE and PD) 13 December 21st, 2006 17:21
No Glow? Hard cold start? Check coolant temp sensor. Jimmy TDI 101 3 January 29th, 2006 08:27
Check Eng Light - Hard start - glow plug - $$$ basco2 VW MKIV-A4 TDIs (VE and PD) 9 January 27th, 2001 19:28
Page generated in 0.13627 seconds with 11 queries
[Output: 135.85 Kb. compressed to 114.32 Kb. by saving 21.53 Kb. (15.85%)]
